Spot sends broken notification links. Really, guys??
Old April 4th 16, 07:46 PM posted to rec.aviation.soaring
Kurt Thams
Default Spot sends broken notification links. Really, guys??
I notice that Spot texts send broken links for text alerts.
They are of the form:
Track his location at http://tinyurl.com/abz3iek(End)
The "(End)" is not actually part of the link, and therefore, breaks the link. If you peal that off, you get directed to the right place.
Or maybe this is being added by an intermediary system and isn't Spot's fault. Does anyone else observe the same broken behavior, and/or correct behavior?
Old April 4th 16, 11:28 PM posted to rec.aviation.soaring
When I send an OK msg I receive a txt :
CH
ll=32.42912,-111.38667
SPOT Check OK. CH on course
Uvalde WGC 2012 SPOT tracking links [email protected] Soaring 2 August 2nd 12 08:15 PM
SPOT mapping links for Ionia regional contest [email protected] Soaring 0 May 26th 12 04:33 PM
Mifflin Region 2 Contest SPOT map links Frank Paynter[_2_] Soaring 0 May 20th 11 03:51 AM
Sports Class Nationals SPOT tracking links Frank Paynter[_2_] Soaring 0 May 1st 11 02:40 PM
Perry SPOT map links Frank Paynter[_2_] Soaring 0 April 16th 11 04:19 AM
