Cobra hatch weather stripping/seal
Old April 11th 16, 01:53 AM posted to rec.aviation.soaring
2G
Default Cobra hatch weather stripping/seal
Does anyone know where I can get the weather stripping that is used on the front hatch of Cobra trailers? The stripping is about 1 inch (25 mm) wide.
Old April 11th 16, 03:07 AM posted to rec.aviation.soaring
JS
You mean this?
http://wingsandwheels.com/cobra-trai...-aluminum.html
Old April 11th 16, 04:47 PM posted to rec.aviation.soaring
Richard[_9_]
You mean this?
or this from McMaster Carr
http://www.mcmaster.com/#standard-ru...heets/=11xq53k
Richard
www.craggyaero.com
Old April 11th 16, 04:57 PM posted to rec.aviation.soaring
Richard[_9_]
You mean this?
Richard
www.craggyaero.com
Weather-Resistant EPDM Foam Sheets and Strips
These EPDM foam sheets and strips have the best resistance to water, sunlight, and oxidation of all the foam we offer.
Closed-cell foam restricts water, air, and gases from being absorbed.
Adhesive-Back Strips
Color: Black
Temperature Range: -40° to 220° F
Cell Type: Closed
For Use Outdoors: Yes
Density: 12 lbs./cu. ft.
Pressure to Compress 25%: 4 psi (Ultra Soft)
Adhesive
1" × 50 ft.
Thick. Thick. Tolerance Type Temperature
Range, ° F Each
1/8" -0.032" to +0.032" Acrylic -20° to 200° 93725K58 $29.11
3/16" -0.032" to +0.032" Acrylic -20° to 200° 93725K68 33.50
1/4" -0.032" to +0.032" Acrylic -20° to 200° 93725K78 37.98
McMaster Carr PN 93725K78 1/4" X 1" X 50ft
Richard
www.craggyaero.com
Old April 28th 16, 12:48 AM posted to rec.aviation.soaring
2G
You mean this?
Richard
www.craggyaero.com
Color: Black
Cell Type: Closed
Adhesive
1" × 50 ft.
Range, ° F Each
Richard
www.craggyaero.com
I found this gasket (Trim-Lok 4100B3X1/16C-25) which costs about a third of the Wings & Wheels product and there is enough to do 2 trailers:
http://smile.amazon.com/Trim-Lok-410...0&tagbase=abba
It has a larger bulb and seals better than the original gasket.
Tom
Old January 2nd 17, 10:17 PM posted to rec.aviation.soaring
JS
Here's another part number that works, a generic automotive trunk seal.
UWS139-25
Several places had no stock, so ordered through stylintrucks.com and it was quickly drop shipped from Precision Replacement Parts for less than Amazon's product.
Easy to install and a tight seal, as 2G reported. I sleeved the joint with a couple of inches of 1/2" OD Latex tubing, McMaster part 5234K12.
Part Name Quantity Price
PRPUWS13925_##3W 1.00 $ 25.31
Total: $33.35
Cobra trailer seal replacement--any previous experience? John Duke Soaring 4 October 5th 15 08:03 PM
102 Astir CS hatch cover Waveguru Soaring 0 June 26th 14 05:00 PM
Weather Seal for 1986 Komet Trailer Ronald Desilets Soaring 3 October 31st 11 07:29 PM
My hatch blew off!! [email protected] Soaring 8 September 9th 09 07:45 AM
Avionic weather-stripping seal needed... [email protected] Soaring 3 July 23rd 07 04:46 PM
