Egress from 1-26
Old May 24th 16, 03:22 PM posted to rec.aviation.soaring
KAIO
Default Egress from 1-26
I'm thinking of buying a parachute for using in a 1-26. I was not able to find any instance of bailout from a 1-26 in the NTSB database. is is really possible, practicable, to egress a 1-26 in flight? Can the 1-26 canopy be ejected?
I know that almost anyone who flies a 1-26 does so without wearing a parachute, so I don't want to discuss the relative merits of having one available (I obviously think wearing a parachute is always a good idea). Just who practical is it.
Any pilot who flies 1-26s wearing parachutes?
Thanks!!!!
Old May 24th 16, 04:26 PM posted to rec.aviation.soaring
Clif McVay
Thanks!!!!
Canopy ejection involves removing the two hing pins. If well maintained and installed correctly they "should" come out easy. (I've never tried it in flight.)
Most 1-26 canopies have a lanyard line to keep the canopy from opening too far when getting in or out.
An ejected canopy attached by such a lanyard could stay attached and present a serious problem.
I use a carabiner clip on my lanyard for a quick disconnect - but only for removing the canopy on the ground.
I do not wear a parachute in a 1-26.
Old May 24th 16, 04:39 PM posted to rec.aviation.soaring
KAIO
Thanks!!!!
Thanks. I figure that the loops at the end of the hinges could be used to eject the canopy. The issue is that, as you point out, there are other points of attachment: the canopy latch and the strong lanyard. Since those three items securing the canopy will need to be pulled in sequence, the chances of doing so successfully are very low.
Thanks again for your help.
Old May 24th 16, 07:24 PM posted to rec.aviation.soaring
kirk.stant
What's the problem with just opening the canopy and climbing out? If you can get in on the ground, you should be able to get out in the air!
As for a chute - I've flown 1-26s both ways. I always wear a chute (paid for it, might as well use it!) in my own glider, but don't always bring it when I fly the club's 1-26.
But I sure like having it on!
Kirk
66
Old May 25th 16, 01:18 AM posted to rec.aviation.soaring
Clif McVay
I've never left an aircraft in flight and I hope I never experience the need. So my hypothetical, inexperienced thought experiments wonder if a canopy that can stay open in controlled flight will continue to behave while I try to exit the cockpit? Or might it suddenly try closing and knock me unconscious? Hmmm....?
Old May 25th 16, 02:41 AM posted to rec.aviation.soaring
Renny[_2_]
Clif,
I would not worry too much about getting out of a 1-26 in an emergency. Folks have exited all sorts of gliders in many different aircraft orientations, speeds, altitudes and with various types of canopies. Those that survived had one thing in common.....They all were wearing parachutes.
Without one you essentially have a zero chance of survival. Some folks, for whatever reason, could not get out and/or were incapacitated, and they did not survive, but with a parachute you will at least have a decent chance of survival.
Please, let's not over think this....Fly with a parachute!!! Consider it an insurance policy!!! ;-)
Thx - Renny
Old May 24th 16, 06:52 PM posted to rec.aviation.soaring
Regarding bailing out of a 1-26, many years ago, one of our club founders, Ed Seymour bailed out of a 1-26 after trying to do a roll and damaging a wing. He was almost hit by the spinning 1-26 after bailing out. Ed lived to tell about it so it can be done.
I have not tried this in flight, but if you release the 1-26 canopy latch and raise the canopy it may stay over to the side and allow egress from the 1-26. This can be done in a 2-33. After releasing the canopy latch, the 2-33 canopy will stay open to the side with no glider control problems. Ed Seymour would demonstrate this to students during instructional flights. As one of Ed Seymour's students I can attest that this demonstration keeps you wide awake.
Chuck Zabinski
"ZC"
Old May 25th 16, 02:36 PM posted to rec.aviation.soaring
Vaughn Simon[_2_]
Well, I've flown them, but never bailed out of one. I don't see why a
properly motivated pilot would have any particular problems though. If
it were me in a badly damaged I-26, I would certainly want the option to
try! One thing in your favor, your airspeed is likely to be low
compared to almost any other glider.
On the other hand, there is a case of a pilot walking away from a 1-26
crash after losing a wing at altitude! I'm obviously happy that it
turned out well, but doubtless that fellow was wishing for a chute all
the way down.
NTSB Identification: MIA97LA211
Accident occurred Saturday, July 12, 1997 in EUSTIS, FL
Probable Cause Approval Date: 02/02/1998
Aircraft: Schweizer SGS-1-26B, registration: N9927J
Injuries: 1 Uninjured.
Old May 25th 16, 05:35 PM posted to rec.aviation.soaring
Jonathan St. Cloud
If I recall correctly this 1-26 collided with a glass glider whose pilot did not get out. Goes to show if it is not your time...
the way down.
Old May 26th 16, 02:58 AM posted to rec.aviation.soaring
BobW
No other glider (or plane) involved. See the March, 1998 "Soaring" mag (online
archive for SSA members) for likely the most comprehensive
description/assessment you can find in print. Almost certainly loss of control
in inadvertent IMC, resulting in pulling a wing off. FWIW, this was the 2nd
known-to-me spun-to-the-ground w. pilot still on-board, non-fatal 1-26
crunch...though this one appears to have come to rest in mature pine trees.
The other one was atop a nekkid Appalachian ridge. Neither PIC - so far as I'm
aware - was wearing a 'chute. Some might infer from these data that 1-26's are
the safest glider in which to spin-in...
Bob W.
the way down.
NTSB Identification: MIA97LA211 Accident occurred Saturday, July 12, 1997
in EUSTIS, FL Probable Cause Approval Date: 02/02/1998 Aircraft:
Schweizer SGS-1-26B, registration: N9927J Injuries: 1 Uninjured.
emergency egress, sans 'chute? Piet Barber Soaring 12 October 27th 12 01:38 AM
Underwater egress Duane MacInnis Piloting 9 December 3rd 03 10:51 PM
