PowerFLARM Tips Update
Old June 21st 16, 05:04 AM posted to rec.aviation.soaring
Paul Remde
Default PowerFLARM Tips Update
Hi,
Is your PowerFLARM "IGC Enabled"?
Tonight I updated my PowerFLARM Tips document with helpful information about
the "IGC Enable" option in PowerFLARM Units.
http://www.cumulus-soaring.com/flarm...FLARM-Tips.pdf
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
Old June 21st 16, 04:08 PM posted to rec.aviation.soaring
Thanks of the tips above.
Is there a way to copy From the Power Flarm the config file that is in it already, to check the settings?
Kevin
92
Old June 21st 16, 04:40 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Kevin
92
Most is in the header of your IGC file. Download it and open with a text editor (Textedit, Notepad). It's before the B records start....
Old June 22nd 16, 01:18 AM posted to rec.aviation.soaring
Thanks
Kevin
92
PowerFlarm Update Problem John Carlyle Soaring 14 April 15th 15 11:20 PM
PowerFLARM Portable Firmware Update: 6.02 Paul Remde Soaring 15 April 10th 15 03:13 PM
PowerFlarm Update? Mike the Strike Soaring 71 March 21st 15 05:32 PM
Portable PowerFlarm hardware update kd6veb Soaring 8 March 22nd 13 10:44 PM
PowerFLARM Display Update Paul Remde Soaring 2 November 11th 10 06:40 PM
