FLARM/Flarmnet question
Old June 22nd 16, 05:47 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Default FLARM/Flarmnet question
I just had chance to use my new Flarmview at the Region V So contest. Spotted gliders OK. I had installed the proper flarmnet database, converted via the fln2flx utility. All I saw was the radio ID of gliders-never the Comp ID. Is there a way to confirm that the flarmnet database installed? Thanks in advance.
Old June 22nd 16, 06:54 PM posted to rec.aviation.soaring
Also check your settings in the Flarmview.
Under the settings for "Target" I believe you will find an option called "Target Label" I don't have it in front of me, but there you may need to state that you want to see the contest number for Flarm targets....
Old June 23rd 16, 01:36 PM posted to rec.aviation.soaring
OK I'll try it
Thanks
Flarm Download Question Roy Bourgeois[_4_] Soaring 6 June 7th 16 05:19 AM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 05:31 AM
FLARM question Eric Bick (1DB) Soaring 13 May 30th 14 02:55 AM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 05:28 AM
Red Box FLARM update question Martin Gregorie[_5_] Soaring 1 June 11th 11 11:13 PM
