Mosquito question
Old July 25th 16, 05:24 AM posted to rec.aviation.soaring
Default Mosquito question
I just bought mosquito 303 and there is an 6x8 inch Inspection hole behind main gear is that factory.
Old July 25th 16, 05:57 AM posted to rec.aviation.soaring
yes. That is how you inspect/service the control connections.
please consider joining the mosquito group
https://groups.yahoo.com/neo/groups/Mosquitos/
Chris
Old July 25th 16, 05:59 AM posted to rec.aviation.soaring
Yes that is Glasflugel standard, all the Mozzy's and Hornet's have the hatch, it is access to the rudder circuit bellcrank and stops, amongst other things
Chris Runeckles
Old July 25th 16, 10:46 PM posted to rec.aviation.soaring
Mine has an air exit vent built in to the hatch - unsure if it's factory or not.
Nick.
Chris Runeckles
Old July 26th 16, 02:45 AM posted to rec.aviation.soaring
Nick.
Chris Runeckles
Hi Nick
that air vent is not standard its a job I did for a customer and the hatch got swapped when the glider was pranged
R-22 vs Mosquito Stuart & Kathryn Fields Rotorcraft 15 May 12th 08 05:25 PM
Ok then, how about the Mosquito? Bob Upp Home Built 5 January 10th 07 03:36 PM
I Want a Mosquito..... Shiver Rotorcraft 5 January 30th 06 06:27 AM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Mosquito fighter-bomber tactics question Kari Korpi Military Aviation 6 April 5th 04 10:09 AM
