Minooka Accident?
Old August 7th 16, 04:45 PM posted to rec.aviation.soaring
Default Minooka Accident?
Anyone in Chicago area know of a glider incident Saturday? We received a sketchy third hand notification and have mostly non pilot friends there. Thank for any steerage or link. Karen
Old August 7th 16, 06:15 PM posted to rec.aviation.soaring
Renny[_2_]
Sad news...
http://www.theherald-news.com/2016/0...field/a9fcd8u/
Old August 15th 16, 03:46 PM posted to rec.aviation.soaring
Sad news...
The NTSB preliminary report has now been posted...
http://www.ntsb.gov/_layouts/ntsb.av...o=3&pgsize=200
Old August 15th 16, 09:16 PM posted to rec.aviation.soaring
Bruce Hoult
Anyone in Chicago area know of a glider incident Saturday? We received a sketchy third hand notification and have mostly non pilot friends there.. Thank for any steerage or link. Karen
Sad news...
Bloody 'ell!
I was confused by the term "chin tow cable release". Looking at photos, it seems the '55 has the aerotow hook approximately under the instrument panel..
http://www.wildbergair.com/photos/ai...90314_051..JPG
According to manufacturer's information, they can come with a hook "on the nose section" (NOT "on the nose"), on the undercarriage fork, or both. Winching is to be carried out only on the hook on the undercarriage, aerotow can be done on the winching hook if that is the only one fitted.
That raises some questions:
- did the NTSB inspector check for a tow hook on the undercarriage? Was there one? Was it in use on this launch? Have to assume no to all three questions, as they didn't mention one and they're not idiots.
- is the aerotow hook far enough back to cause a noticeable pitch up if a slack tow rope comes tight suddenly?
- the report says the glider was pointing left with the left wing down on the second wing drop. Did it slalom enough to get slack rope on recovery?
It's hard to imagine why you'd get a 30 - 40 degree pitch up unless the glider decided to winch launch behind the towplane. Short of an incapacitated pilot anyway.
Old August 15th 16, 11:56 PM posted to rec.aviation.soaring
Sad news...
Bloody 'ell!
http://www.wildbergair.com/photos/ai...090314_051.JPG
The term "chin hook" seems to well describe the low forward hooks some gliders have to try to comply with the expectation of a nose hook. Being further forward will likely help with yaw to some degree, but most are not all that much higher than the CG hook and thus will only have limited benefit in terms of pitching moment when the big yank comes.
True nose hooks accomplish both.
Another example of not pulling the release early when stuff starts to go wrong. My comment assumes pilot could get to the release.
Sad
UH
Old August 16th 16, 03:31 AM posted to rec.aviation.soaring
IA DPE
I believe that ship sold on W&W just a few months ago, as I called about it.
Old August 8th 16, 01:32 AM posted to rec.aviation.soaring
Gianni Isotope
Another early news report: http://patch.com/illinois/channahon-...ark-man-s-life
Old August 11th 16, 10:00 PM posted to rec.aviation.soaring
Skytime
Witnesses said that they saw one of wings of the glider "dip" shortly after it was released from the tow plane. The glider then stalled and "nose dived" into the field.
No other details of the accident. The initial accident report from the FAA indicates that the aircraft was a PLZ Bielsko SZD55 glider of "pending" registration. It is classified as an "Experimental" aircraft in the "Racing" category.
Old August 12th 16, 03:28 PM posted to rec.aviation.soaring
The preliminary report is now available on ntsb page. Has a little clearer description of events. Horrible and unneeded loss.
Old August 15th 16, 11:33 PM posted to rec.aviation.soaring
FZ[_2_]
There is a history of collapsing of the back rest in SZD-55.
Mine was equipped by the previous owner with a custom made wood inserts, supposedly preventing of such events. Collapsing of the back rest would certainly cause pilot to fall back and sudden back pull on the stick.
Following stall would be consistent with this scenario.
yet another accident [email protected] Soaring 0 May 5th 13 06:07 PM
Accident? on 8-27-92 Chris Wells General Aviation 8 January 10th 06 02:15 AM
F6F accident Larry Cauble Naval Aviation 4 October 14th 05 06:19 PM
MU2 accident Big John Piloting 16 April 13th 04 03:58 AM
KC-135 accident Big John Piloting 3 November 19th 03 04:36 PM
