Wing Waxing
Old September 9th 03, 05:42 PM
Marske Flying Wings
Default Wing Waxing
I have often heard that wing waxing does not really help performance but
have never heard anything definitive but my own experiences with the Marske
flying wings lead me to believe that at least for the marske designs it
improves performance.
On our first flights in the Marske Pioneer we had upper and lower spoilers
and although it took some care to adjust the pitch when in use they worked
fine. Upon waxing the wing... just the upper surface, the pitch control
became eratic as the glider was very quick to gain airspeed. so we blocked
off the lower spoilers and corrected the difficulty in operating the
spoilers.
Recently just before our local contest I waxed the upper surface and part of
the lower surface to find that again pich control with the spoilers extended
was more difficult since the glider so easily picked up speed with any pitch
change.
Does anyone else have similar experiences?
-mat
Marske Flying Wings
http://www.continuo.com/marske
Old September 9th 03, 11:09 PM
Bob Mowry
What happens if you try the stall test with the waxed wings.
Inquiring minds want to know
-bob
Old September 10th 03, 03:59 AM
Marske Flying Wings
The unconventional slow speed in a stall attempt is still there. But I will
have another opportunty to try it again soon and record it more extensively
on video.
In the last few days I was able to hold the Marske Pioneer in the high angle
of attack position and rotate 360 degrees with holding the rudder fully to
the left. I also shifted the moveable weight around. If I enter the stall
too quickly the airflow detaches and I can only go to about 30 mph... but
with care I can go down to about 20 mph.
I wish in some way I was able to record the changes in the waxing this
season.... maybe I'll take the wax off at the end of the season and start
next spring to do some performance tests before and after waxing.
-mat.
"Bob Mowry" wrote in message
om...
-bob
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 09:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 04:52 AM
Wing Extensions Jay Home Built 22 July 27th 03 01:23 PM
