Cambridge 302/Oudie
Old August 22nd 16, 11:03 AM posted to rec.aviation.soaring
Dave Latimer
Default Cambridge 302/Oudie
Every time I declare a task from See You running on an Oudie to my
Cambridge 302 it changes the settings in the 302 to metric. Anyone
else had this problem? Thanks Dave
Old August 23rd 16, 07:19 PM posted to rec.aviation.soaring
Oscar-Hotel-Mike
I did have in a previous glider an Oudie 1 and then 2 connected to a 302 and never saw this happen. But I never used this combination of devices to declare a task so my next comments may be rather dumb questions.
Have you checked the Oudie is not set to metric? I have to assume not but had to be asked. I also assume your 302 has been upgraded for the GPS issue (http://aviation.derosaweb.net/cambridge) - but this might not have anything to do with your issue.
Two generic ideas. 1) Use the http://naviter.com web site's forum to ask the question. 2) Contact Cambridge to see if they know anything.
Sorry to not be more helpful.
Good luck
Oudie to Cambridge HGXC[_2_] Soaring 19 May 4th 16 09:35 AM
Oudie 2 to Cambridge 302 [email protected] Soaring 1 April 19th 16 06:09 AM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 06:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 04:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 6th 04 12:22 AM
