Minimum Pilot Weight in a Pilatus B-4
Old October 4th 16, 04:43 AM posted to rec.aviation.soaring
Default Minimum Pilot Weight in a Pilatus B-4
Does anyone know the minimum payload weight for a Pilatus? The max gross is given in the manual, but there seems to be nothing for how light someone can be before adding ballast.
Old October 4th 16, 05:49 AM posted to rec.aviation.soaring
AS
The minimum weight in the pilot's seat should be on the placard but ultimately, you can find out by doing a W&B. The POH should give you the max. aft CG and you can figure out what weight you need in the seat to achieve that position.
Uli
Old October 5th 16, 04:51 AM posted to rec.aviation.soaring
George Haeh
I was close to the limit at 155#. Definitely agree with the advice
to check the W&B. Adding a chute will help.
The max gross
light someone
but
give you the
seat to
Uli
Old October 5th 16, 06:16 AM posted to rec.aviation.soaring
I own #310, and it has a minimum of 53 kilos, max of 97 kilos.
It has been repainted in the past.
There is also a Pilatus B4 group on Facebook btw.
Old October 5th 16, 06:50 AM posted to rec.aviation.soaring
George Haeh
The max gross
light someone
but
give you the
seat to
Uli
Minimum amount of Maximum pilot weight Nyal Williams[_2_] Soaring 1 May 22nd 11 11:34 AM
Airlines Cut Minimum Pilot Experience to 500 hours and Below Larry Dighera Piloting 201 December 2nd 07 06:53 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 05:20 AM
pilot weight and gliding John Lee Soaring 4 August 31st 03 07:53 PM
Pilot weight and gliding JohnH Soaring 26 August 28th 03 12:08 AM
