L'Hotelier Fitting Safety Pins
Old October 13th 16, 02:11 AM posted to rec.aviation.soaring
Dan Marotta
Default L'Hotelier Fitting Safety Pins
Those bobby pins are used extensively on my Stemme and I lost two that
fell out of their retaining strings during taxiing operations leaving me
with only one spare. A quick search found 1.2 mm hitch pins at WalMart
(of all places). I got a bag of 50 pins for under $8. Here's a link
https://www.walmart.com/ip/50pcs-R-Pin-Mechanical-Hitch-Hair-Tractor-Clip-Cotter-Kits-1-2mm-x-20mm/192285117?action=product_interest&action_type=titl e&beacon_version=1.0.1&bucket_id=irsbucketdefault& client_guid=08eca404-93c5-47c8-8bad-9db956f82326&config_id=106&customer_id_enc=&findin gMethod=p13n&guid=08eca404-93c5-47c8-8bad-9db956f82326&parent_anchor_item_id=145509336&paren t_item_id=145509336&placement_id=irs-106-t1&reporter=recommendations&source=new_site&strate gy=SMT&visitor_id=a431WZ4QnJIK7iObjxmdVg
for anyone needing the same. I've tried them and they fit.
Dan, 5J
Old October 13th 16, 04:23 AM posted to rec.aviation.soaring
kirk.stant
that fell out of their retaining strings during taxiing operations
leaving me with only one spare.Â* A quick search found 1.2 mm hitch
pins at WalMart (of all places).Â* I got a bag of 50 pins for under
$8.Â* Here's
a link for anyone needing the same.Â* I've tried them and they
fit.
Ah yes, the aviation department of Walmart; personally I prefer McMasterCarr's aviation line, or locally the aviation branch of Rural King, but in a pinch...
Way better than Harbor Freight's aircraft parts store!
(It's just the Jack Daniels' talkin, bro! ;^)
Kirk
66
Old October 13th 16, 08:02 AM posted to rec.aviation.soaring
When a fellow ASW-15 owner in my club lost some of his pins I bought a couple dozen of the AN safety pins mentioned in the LBA AD from Aircraft Spruce.. More expensive than the Walmart option but better? Not really. The Schleicher TN on the AD offers a pin part number to order from them the same style of pins you got at Walmart and says right in the TN that they are Ford parts. For some reason when my ASW-15 came over from Germany (1998) it had AN type pins on the airbrake connections (which use the up/down wedge L'Hoteliers) and the bobby pins on the ailerons (which have the rotating type L'Hoteliers). Another club member who has just bought an ASW-20 has been looking for the captive safety pins referred to in the AD as Schempp-Hirth pins - an ASW-19 in the club has them and they seem like a really good solution. So far no luck in finding a source for them.
Up here in the Great White North we frequently use the aviation department of Canadian Tire for our needs.
Old October 13th 16, 03:06 PM posted to rec.aviation.soaring
Casey[_2_]
$8.Â* Here's
fit.
Dan, 5J
Good find and thanks Dan.
I keep safety wire in my trailer in case I loose a pin. The AD states "Enlarging the safety pin guide hole diameter to a min of 1.2mm (0.05 in.) to accommodate a safety wire or pin, as applicable.
But under that is what I wonder if anyone has done because I do not have this.
"Fabricating a placard (using â…› inch letters) with the following words:"
"All L'Hotellier control system connectors must be secured with safety wire, pins, or safety sleeves, as applicable, prior to operation." and
"Install this placard in the glider or sailplane within the pilot's clear view."
Casey
Old October 13th 16, 04:21 PM posted to rec.aviation.soaring
$8.Â* Here's
fit.
Dan, 5J
Casey
If you have not installed the placard, assuming the AD applies to your glider, you glider is not airworthy and should not have passed the last annual or condition inspection.
It's easy to do. Print it, laminate(office tape will do in a pinch) and install with double stick tape.
Easy Peasy
UH
Old October 13th 16, 07:47 PM posted to rec.aviation.soaring
James Thomson[_2_]
that
WalMart
Dan, 5J
According to LBA AD 1993-001/3 the 1.2 mm pins are Ford reference
number 1473 931
Whether Ford still supply is another matter...!
Old October 14th 16, 12:50 AM posted to rec.aviation.soaring
Casey[_2_]
Easy Peasy
UH
AD97-08-06 Note 1 "This AD does not apply to gliders and sailplanes that do not have a U.S. type certificate (i.e.., experimental category); however the FAA strongly recommends compliance with the intent of this AD for airplane involved in U.S. operation where a U.S. type certificate is not necessary.
Casey
Old October 14th 16, 01:44 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Was it a pinned L'Hotelier that failed on the Nimbus 4M crash in Washington? Does anyone know of failures with properly pinned L'Hotelier?
Old October 14th 16, 05:14 PM posted to rec.aviation.soaring
Dan Marotta
I don't see how a properly connected and pinned fitting could fail
unless the ball or socket was worn beyond specifications. My guess,
with absolutely no actual information, would be that there was a
material failure and something broke rather than became disconnected.
It would be interesting to see pictures or read the NTSB report. Do you
have more information about the crash?
Dan, 5J
Old October 14th 16, 05:27 PM posted to rec.aviation.soaring
http://www.ntsb.gov/_layouts/ntsb.av...no=1&pgsize=50
Complete Hotelier Connections For Sale (Brand New) $400 Scott Alexander[_2_] Soaring 2 July 19th 12 11:40 PM
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 9th 07 12:15 AM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 04:41 PM
Brass Compression Fitting Brass Thread Fitting Sale on good price valvetom Piloting 0 November 28th 06 03:26 AM
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA [email protected] Soaring 0 September 11th 06 04:48 AM
