Tools/code to produce heatmaps from .igc log files?
Old October 29th 16, 11:55 PM posted to rec.aviation.soaring
son_of_flubber
Default Tools/code to produce heatmaps from .igc log files?
I'm looking for a tool to produce a heatmap from a set of .igc files based on how many GPS fixes are in proximity of a region.
Also interested in other ways to data mine sets of .igc files.
Motivation is curiosity.
Old October 30th 16, 12:22 AM posted to rec.aviation.soaring
Richard[_9_]
Way back in the beginning of PDAs with flight computers WinPilot had a thermal advisor a file that could be developed by the PC version of Winpilot from IGC files. The file was copied to the PDA and could be view on the Winpilot PDA by turning on the function.
It seemed to worked well in the mountains but worthless in the flat lands. Probably because of the thermal producing peaks.
Richard
www.craggyaero.com
Old October 30th 16, 03:23 AM posted to rec.aviation.soaring
son_of_flubber
Yes I agree that a heat map may have little practical value because the terrain, clouds, etc., and a bit of experience, and some time to poke around, lead you to lift in the mountains.
I'm just curious about a heatmap view of my season of soaring. I'm not looking for a practical payoff.
It's interesting that WinPilot tried to exploit heatmaps 'back in the day'.
Old October 30th 16, 01:02 PM posted to rec.aviation.soaring
Muttley
you could check out this site and you may be able to get a useful contact there
http://www.aerodrome-gruyere.ch/thermap/
Muttley
Old November 4th 16, 02:36 PM posted to rec.aviation.soaring
Benjamin Meier
Am Sonntag, 30. Oktober 2016 00:55:39 UTC+2 schrieb son_of_flubber:
This Project from our flexible winged friends might be worth a click too.
http://thermal.kk7.ch/
Make sure you don't miss the links in the Feedback/Links section.
Benjamin
Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM Larry Dighera Piloting 29 December 2nd 15 08:29 PM
How do you de-code MIME files? [email protected] Aviation Photos 0 June 2nd 07 05:26 PM
Global Military Aircraft Systems To Produce and Missionize The C Otis Willie Naval Aviation 0 September 23rd 05 11:43 PM
Will this hanging shape produce lift? Joel Price Home Built 4 March 31st 04 12:09 AM
Do winglets produce thrust? Bob Salvo Soaring 60 December 6th 03 05:58 PM
