Best lasting tire for self launcher hard surface
Old October 30th 16, 01:48 AM posted to rec.aviation.soaring
Default Best lasting tire for self launcher hard surface
Currently flying a DG400 off a public airport with an asphalt surface. A Condor tire was on the bird when I go it.
Looking for recommendations for the best lasting 5.00-5 tire for asphalt.
Michelin Air, Goodyear Flight Special II or Goodyear Special Custom III, or any other longer lasting tire.
Kevin
92
Old October 30th 16, 02:37 AM posted to rec.aviation.soaring
JS
Kevin
92
Good Year Flight Custom 111 with Leak-Guard or Air-Stop tube.
Juat one vote.
Old October 30th 16, 03:48 PM posted to rec.aviation.soaring
Juat one vote.
Jim, are you happier with those tubes vs a Tost?
Kevin
Old October 30th 16, 06:43 PM posted to rec.aviation.soaring
JS
Juat one vote.
Kevin
Kevin, Yes I suppose. All the air stayed in on my shift.
Should mention the Flight Custom 111 is tall and doesn't fit in every glider's wheel well.
Old October 30th 16, 07:12 PM posted to rec.aviation.soaring
Juat one vote.
Kevin
Old October 30th 16, 08:51 PM posted to rec.aviation.soaring
Jonathan St. Cloud
On a related question, how offend are you changing tires? Is is more mileage or time? My trailer gets maybe a thousand miles give or take a few hundred miles per year, and is a dual axle.
Old October 31st 16, 05:42 PM posted to rec.aviation.soaring
Dan Marotta
My Stemme has Goodyear tires and, after about 85 landings, still look
new. I think I'll wear them out before the sidewalls crack.
Juat one vote.
Kevin
Dan, 5J
Old October 31st 16, 09:36 PM posted to rec.aviation.soaring
Thanks Dan,
Thats what I am looking for.
Kevin
Old October 30th 16, 03:44 AM posted to rec.aviation.soaring
Kevin
92
FWIW, there is an old guideline about aircraft tires which says it all depends on your use habits. If you wear out the tread first, buy the cheapest you can find since, by regulation, they all use the same tread compound. OTOH, if you let the aircraft sit until the sidewalls crack before you use up much of the tread, buy top quality tires such as Goodyear because they use the best sidewall material to resist weather checking.
best self-launcher propulsion system? key[_2_] Soaring 35 January 17th 12 04:50 PM
Predecessor to the ETA - BIG ANCIENT self launcher Bob Soaring 0 October 17th 10 09:36 PM
For Sale: Discus A TOP self launcher Chris Soaring 0 December 1st 08 10:57 AM
IF I HAD A ROCKET LAUNCHER X98 Military Aviation 7 August 13th 04 09:17 PM
