Wanted used 3 1/8 in Altimeter
Old January 8th 17, 11:19 AM posted to rec.aviation.soaring
Default Wanted used 3 1/8 in Altimeter
Looking to purchase a used 3 1/8" (80 mm) Altimeter
Tim Hanke
Adirondack Soaring
Saratoga Springs, NY USA
518-693-6949
Old January 8th 17, 05:34 PM posted to rec.aviation.soaring
Dan Marotta
I have one, but you probably won't be interested. It's calibrated in
feet, but each revolution of the dial is 3,000'.
Here's a link to a pictu
https://www.dropbox.com/s/2s6k2tur44...meter.lnk?dl=0
Tim Hanke
Adirondack Soaring
518-693-6949
Dan, 5J
Old January 8th 17, 05:49 PM posted to rec.aviation.soaring
Dan Marotta
Here's a link that actually works:
https://www.dropbox.com/s/qnekoxc26d...meter.jpg?dl=0
Tim Hanke
Adirondack Soaring
518-693-6949
Dan, 5J
Old January 8th 17, 06:02 PM posted to rec.aviation.soaring
chuck[_3_]
"but each revolution of the dial is 3,000"
That's an altimeter for an optimist.
Old January 8th 17, 06:25 PM posted to rec.aviation.soaring
Dan Marotta
It was amazing how quickly I got used to it, but it is odd and only the
adventurous should try it.
Dan, 5J
Old January 8th 17, 06:33 PM posted to rec.aviation.soaring
Sarah[_2_]
Try http://flyaqi.com/pressure.htm
Tim Hanke
Old January 8th 17, 08:27 PM posted to rec.aviation.soaring
Michael Opitz
Tim Hanke
Adirondack Soaring
518-693-6949
Tim,
Watch eBay:
http://www.ebay.com/sch/i.html?
_odkw=altimeter&_osacat=0&_from=R40&_trksid=p20455 73.m570
..l1313.TR3.TRC2.A0.H0.Xaircraft+altimeter.TRS0&_n kw=aircraft+alt
imeter&_sacat=0
If it is for a "new" Twin Astir from Germany, the handbook specifies
one that is TSO-C10 and 35,000' compliant. Put something else in
there, and the Feds may refuse it on the certification checks.
Something else is not legal, and could lead to insurance rejection of
a claim in case of a later accident...
They will pop up for between $100 and $250 depending on age and
condition. You can always pick up a cheap non functional one to
use as a trade in core if buying an overhauled one should you want
t go that route.
RO
Old January 8th 17, 09:29 PM posted to rec.aviation.soaring
Ross[_3_]
Michael and Tim, please contact each other about the ASI from the Twin
Cheers
Winter altimeter exchange wanted [email protected] Soaring 0 November 6th 14 05:49 PM
tso altimeter Phoenixmotoman Soaring 24 December 8th 10 12:55 PM
WTB: used 57mm Altimeter OR swap for 80mm Altimeter joesimmers Soaring 0 November 3rd 09 11:59 AM
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Altimeter off kevmor Instrument Flight Rules 11 March 26th 07 12:11 PM
