HP14
Old January 18th 17, 05:05 PM posted to rec.aviation.soaring
Default HP14
What are the pros and cons of flying/owning one of these old girls.I flew gliders waay back in the early seventies at port augusta and shortly before going on to further study our CFI , Geff finished building and was airborne. I thought it was a wonderful looking bit of kit then and now . might look at getting one yet as a semi retirement,thingy. Any insights, info,etc, muchly appreciated. p.s. Planning on flying the flat dry hinterlands of Sth Australias Murray Mallee country. cheers Ken
Old January 18th 17, 09:38 PM posted to rec.aviation.soaring
SoaringXCellence
Default HP14
Ken,
If you haven't already, you need to go the the soaridaho.com site and study there.
http://www.soaridaho.com/Schreder/
If the ship was well built and maintained, you should be delighted in the performance. It has a light wing loading by current standards and seems to get close to the 40:1 claimed, if it is kept clean and smooth.
If it was built to the plans, it isn't 15M and is less than 18M, so it doesn't really fit into any present FAI class.
The V-tail mixer may need some attention (lubrication and cable tightening), It seems the -14 had a properly sized tail surface. So no "waddle" that came with some earlier v-tail designs.
Hope you have a good time, I wish I fit in one a little less snug.
Old January 19th 17, 07:40 AM posted to rec.aviation.soaring
Mike C
Default HP14
On Wednesday, January 18, 2017 at 1:38:37 PM UTC-7, SoaringXCellence wrote:
Ken,
Club class is an FAI class.
Mike C
Old January 19th 17, 03:54 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default HP14
Mike C
But per FAI rules, no Club Class glider can have a span of greater than 15 meters. It is not just a performance range, as permitted here in the US.
The HP-14 is a wonderful sailplane. Maybe not the easiest to fly well, but certainly not difficult to fly. And, there is one for sale there in Oz.
http://www.sailplanes.co/sailplanes/...lanes/hp14v_41
Steve Leonard
HP-14 Serial 1
N4736G
Old January 19th 17, 10:34 PM posted to rec.aviation.soaring
Mike C
Default HP14
Mike C
Steve Leonard
HP-14 Serial 1
N4736G
Correct, my mistake.
Old January 20th 17, 01:38 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Mike C
Steve Leonard
HP-14 Serial 1
N4736G
Std Cirrus at 16m is on the IGC club class handicap list so span alone may not disqualify
http://www.fai.org/downloads/igc/SC3AH_2016b
Colin
Old January 20th 17, 06:24 AM posted to rec.aviation.soaring
Bob Kuykendall
Default HP14
On Wednesday, January 18, 2017 at 12:38:37 PM UTC-8, SoaringXCellence wrote:
...It seems the -14 had a properly sized tail surface. So no "waddle" that came with some earlier v-tail designs.
Well, it depends. The standard HP-14 plans set shows the HP-14 as having the same size tail as most of the Schreder birds from the HP-11 through the HP-18. Steve Smith once did a stability analysis of the HP-14 that shows it to have a relatively narrow margin of static stability. That's not necessarily bad, but it does mean greater pilot workload than were there a greater margin.
Several HP-14 builders made larger tails for their ships; some by using longer skins and spars, some by adding extended tips to the ruddervators.
I've flown HP-11 and HP-18, but never HP-14. But anyhow, my impression is that they're not all that hard to come to terms with. The hard part is learning to deal with the 90-degree landing flaps. They offer about the best glidepath control there ever was, but the dearth of similarly-equipped two-seaters means that you pretty much have to learn to use them on your own.
BTW, don't believe the haters who say that once you crank on the flaps you can't back off. That's just bull****. I've gone from full positive to get down onto the deck, full negative to float all the way to the turnoff (halfway down a 9000-foot runway), and then back to full positive to get down and stopped, all during the same approach. It's once you figure out the feed-forward trick.
--Bob K.
Old January 21st 17, 05:30 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default HP14
I have about 20 or so hours in an HP-14 and 60 or so in an HP-16. Also have about 1400 hours in a Zuni, so fair amount of flaps only time.
The key with flaps is simple. You know that when you open spoilers, you add drag and you have to lower the nose to maintain speed. Well, flaps add drag, too, so you have to lower the nose because of this to maintain speed. Then, there is the secondary effect that is really primary. Draw a line through the leading edge and trailing edge of the wing. Note this angle on the fuselage, and relative to the tail Now, drop the flaps. Keep that line fixed at the leading edge, and the trailing edge of the flap. See how it is now tipped significantly relative to the fuselage and tail? You have effectively just added a bunch of incidence to the wing, so to keep it at the same angle of attack, you have to push the nose down. Inverse is true when you retract the flap. You have to pull the nose up as you retract the flap, as you reduce the effective incidence and angle of attack. That is what Bob means by feed forward. Add flaps, lower the nose. Reduce flaps, raise the nose. Until you are ready to touch down, you MUST stay above flaps up stall speed. If you do this, it is a piece of cake to do what Bob described.
As to your initial question.
Pros:
Not highly sought after, so low cost of entry.
Very good performance for what you have to spend. Nearly the equal or early Std Class Glass at 1/3 to 1/2 the cost.
Metal, so no gelcoat issues of you decide to tie it out.
Not too bad to assemble. Each one may have tricks to be done, such as order of installation of pins. On mine, it is Drag pin, lift pin, then main pins. On another I know of, the drag pin is the last pin on each wing. Learn the plane.
Cons:
Low entry price means low exit price and limited market to sell to.
Impression by others that they are "heavy and hard to assemble". The plane does carry more of its empty weight in the wings, but it is not too bad. A third person is helpful if you don't have a wing rigging dolly, simply because the root chord is 40 inches and the flap needs to be aligned with the driver as you bring the wing in to place.
Trailers are often not well thought out on Homebuilts. The builder spent all his energy on the plane, and the trailer may be an afterthought. Work on fixtures, and amaze your friends with how easy it is to rig.
It was a project when it was started, and it can remain a project for ever. Homebuilts have more opportunities for changes to be made than factory builts.
Why don't I have more time in mine? I have too many other toys!
Steve Leonard
Old January 21st 17, 08:36 AM posted to rec.aviation.soaring
Bob Kuykendall
Default HP14
Yeah, what Steve said!
--Bob K.
Old January 21st 17, 04:26 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Default HP14
--Bob K.
Ditto everything Steve L. & Bob K. have said. That's with 2260 hrs in
landing-flapped-only gliders, 196 in an HP-14...nearly always rigged/derigged
each flight, never with more than one additional person (on the wingtip,
including - more than once! - a 5', 120-ish lb lady
glider-pilot/fellow-club-member-friend, wingtip helper on the HP-14). Most
everyone readily offers hearsay, typically without labeling it as such, the
more so when it comes to "non-mainstream gliders." Sometimes, it's even
"generally accurate"...though the devil is always in the details. Best to get
the details from those with first-hand experience.
The only reason I sold my HP-14 when I did was it (1981) fell only into the
open class had I chosen to fly it in contests, and I wanted a ship in which if
I came in last I'd be certain it was due to the pilot and not the ship.
Wonderful bird, which encourages/rewards attention to rudder use, at least in
the as-designed-span, V-tailed, form.
Bob W.
