Gherlein winch rear axels
Old February 14th 17, 03:44 AM posted to rec.aviation.soaring
Default Gherlein winch rear axels
No markings. Were these manufactured with some standard rear axel or a variety of parts? Most look like a GM 48 inches wide, between brake drums.
Old February 14th 17, 04:28 AM posted to rec.aviation.soaring
Join Yahoo WinchDesign group and ask. As far as I know, they were built with whatever happened to be available at the time. Might be cheaper to replace the entire axle with, say, a Ford 9 inch or something newer, for which parts will be more readily available.
Marc
Old February 14th 17, 05:12 AM posted to rec.aviation.soaring
Frank Whiteley
Plenty of websites. The design engines were 283 and 327 IIRC from plans, so a '60's generation diff would seem to make sense. Several web sites with ID methods.
http://www.roadkillcustoms.com/hot-r...#axzz4Yd41BzKS
http://www.crankshaftcoalition.com/w...identification
http://www.jalopyjournal.com/forum/t...ential.975907/
What model and serial number Gehrlein?
Old February 14th 17, 06:01 AM posted to rec.aviation.soaring
Thank you for the ref pages.
This winch was delivered with a very tired old 327. No winch model markings or serial numbers otherwise. Nothing found on the winch engineering site about stats or others experiences with one or two drum Gerhlein models or didn't look far enough.
Old February 14th 17, 06:47 AM posted to rec.aviation.soaring
Look on "Winch Design" not "Winch Engineering". Not the same group.
Marc
Old February 14th 17, 10:27 PM posted to rec.aviation.soaring
Frank Whiteley
After a little more digging, this may help assuming the diff is also chevy
http://www.348-409.com/differential.html
Old February 16th 17, 07:46 PM posted to rec.aviation.soaring
With Frank's refs, found the differential markings 9L3 and 2T on our 48 inch axel.
Likely Ford 9 inch 1960's two ton, Mercury or Mustang. Still looking for a more current 48 inch equivalent with the same gear ratio.
No joy searching or posting on the Winch Design group, but we persist.
Thank you.
Old February 16th 17, 11:38 PM posted to rec.aviation.soaring
Thank you.
https://groups.yahoo.com/neo/groups/winchdesign/info
I'm the owner/moderator no post seen?
Marc
Old February 17th 17, 05:10 AM posted to rec.aviation.soaring
AXLE! Not AXEL! We ain't figure skating, are we?
Old February 17th 17, 05:13 AM posted to rec.aviation.soaring
Scott Williams
On Thursday, Fy 16, 2017 at 4:38:33 PM UTC-6,
I used to be a pretty fair gearhead, are there any pictures of the axle, what gear ratio is the present axle?
Scott W.
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 12:45 PM
Looking for L-23 rear canopy - US [email protected] Soaring 0 May 9th 09 05:30 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 01:33 AM
ASW 24&27 rear fuselarge vents? Udo Rumpf Soaring 6 October 24th 03 04:04 AM
