IGC approval - LXNAV Nano 4 Flight Recorder
Old February 14th 17, 08:16 AM posted to rec.aviation.soaring
Default IGC approval - LXNAV Nano 4 Flight Recorder
I am pleased to announce IGC-approval for the LXNAV Nano 4 Flight Recorder
from LXNAV of Celje, Slovenia, for "all flights" including world records.
This is a small stand-alone recorder with a screen, and sensors for engine operation using both low and high frequency noise.
The low frequency sensor has peak sensitivity at about 150 Hz and records under the ENL code.
The high frequency sensor has peak sensitivity at about 8KHz, records under the MOP code and is for use with small jet engines.
Three numbers under each code are part of in each fix in the IGC file.
The IGC-approval document may be downloaded either from the FAI/IGC web site or the GFAC web site, see below.
There are now 58 different types of IGC-approved Flight Recorders from 20 different manufacturers.
If you own or fly with one of these recorders, it is recommended that you download its latest IGC-approval document from one of the web sites given below, and note any changes that may affect how you operate it.
A table of all IGC-approved FRs with links to Approval Documents is on the GFAC web site:
www.ukiws.demon.co.uk/GFAC
The table can be viewed directly at:
www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf
This document includes the following:
(1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents in the right hand column under "Date of Latest Document".
(2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of name.
(3) a diary of all IGC-approval activity from the first IGC-approvals in 1996 to the present day, most recent events first.
(4) a history of GNSS Flight Recording in IGC together with pictures of some early Recorders.
Navigating the IGC web site:
go to: www.fai.org/igc-documents
Scroll down and click "Flight Recorders",
look down and click on: "IGC-approved Flight Recorders - Approval Documents"
then click on "IGC-approval Documents for all IGC-approved Flight Recorders"
This will call up a list of documents, the first one being "All IGC-approved FRs - table, links to approval documents, general information and history"
This table lists the name and main characteristics of individual IGC-approvals and in the last column of this table there is a link to individual documents, click the link for the document to be called up
The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander.
These can be called up by clicking on the document name.
A box will appear at the bottom of the screen with what has been downloaded, click on "Open" to view the document, which will also have been saved in your Downloads folder.
IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders.
The Technical Specification is available through the igc-documents web site above
or
directly from the GFAC web site:
http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf
Programs that have been notified to IGC for the analysis of IGC files are listed at:
www.ukiws.demon.co.uk/GFAC/documents/analysis programs for igc flight data files.pdf
The IGC Shell program for Validation of the structure of IGC files may be downloaded he
www.ukiws.demon.co.uk/GFAC/downloads.htm
This downloads the file IGCDLL.zip, which when un-zipped, gives the free IGC Shell program. This web site also contains the latest FR Manufacturers’ Data Link Library (DLL) files that are used by IGC Shell and other programs to Validate the structure of an IGC file. The IGC file Validate check ensures that the IGC file came from a serviceable and secure FR, and the file is identical to when it was originally downloaded. This check is required before a flight performance recorded in the IGC file can be approved to the standards of IGC.
Finally, the Sporting Code for gliding (SC3) and its annexes A-D may be downloaded at: www.fai.org/igc-documents
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC)
Old February 20th 17, 02:14 PM posted to rec.aviation.soaring
We're thinking of buying one as our first "glide computer" (no space in panel). Anyone have one and could give a review? Not much written about it yet by any users...Thanks! Kristin
or
Ian Strachan
Old February 20th 17, 03:43 PM posted to rec.aviation.soaring
Renny[_2_]
or
Ian Strachan
Kristin,
As I understand this, the fist batch of Nano 4s are just being shipped out this week to dealers around the world, so I doubt that anyone (other than LXNAV company personnel) has any experience using one. In a few weeks you should be able to get some feedback from new owners....Thx - Renny
Old February 21st 17, 11:24 AM posted to rec.aviation.soaring
krasw
Looks like it is basically Nano3 with large display. It is a logger, not flight computer.
Old February 21st 17, 06:37 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
it
flight computer.
One difference is that as a logger, it can record Engine Noise from Jets
(MOP) as well as Petrol Engines. Few other loggers can do this. BUT it is
the pilot’s responsibility to position the Recorder where it can
‘hear’ the engine. Failure to do this can/will disqualify any claim.
Caveat Emptor!
IGC approval for the LX9000HAFR Flight Recorder Ian Strachan Soaring 0 August 3rd 16 11:29 PM
IGC approval for S-10 and S-100 Flight Recorders made by LXNAV Ian Strachan Soaring 0 April 29th 16 07:49 AM
IGC-approval for Triadis RU2 and update to LXNAV externalMeans-of-Propulsion recorder box Ian Strachan Soaring 0 May 7th 13 04:24 PM
IGC-approval of the LXNAV Nano GNSS Flight recorder Ian Strachan Soaring 5 September 1st 10 03:41 PM
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 09:00 PM
