Oudie starved for power
Old February 19th 17, 05:14 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default Oudie starved for power
Help!
I run my Oudie from my V7 so that it gets all the flarm data from my Flarm Core. Unfortunately it tends to run out of battery power towards the end of the flight, even though the V7 is supplying juice.
I measure the current draw of the Oudie in this setup and it came in around 160ma. I then plugged it into the Colibri II connection I have a s a GPS backup, and it then drew 360ma. The red charging light also came on. I moved it back to the V7 and the charging light went back to green and current again dropped to 160ma.
Conclusion: V7 output is current limited and starving the Oudie in flight.
Solution: so what I need is power from the Colibri II power supply, but data from the V7. Anyone ever done this? I could make some funky splitter cable, but I am worried about ground loops between the V7 and the Colibri II power supply.
Any suggestions or experience solving this problem?
Matt
OUDIE [email protected] Soaring 31 November 5th 16 04:19 PM
Oudie 5.19 Bug Lauren Soaring 3 June 4th 14 07:57 PM
Power FLARM power Andy[_1_] Soaring 9 June 6th 12 01:38 AM
Oudie Steve Hunt Soaring 2 July 8th 11 01:19 AM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 03:44 AM
