Cold weather operations for two-stroke self-launchers?
Old March 8th 17, 01:43 AM posted to rec.aviation.soaring
Paul Villinski
Default Cold weather operations for two-stroke self-launchers?
Can anyone with experience self-launching in cold winter conditions share germane experience? Any specific concerns or issues operating an air-cooled, two-stroke at, or near, freezing temps? Any experience with carb icing? Any deal-breakers? Any tips? Contemplating occasional winter flights in the Northeast, self-launching with a Rotax 505. Thanks!
Old March 8th 17, 01:41 PM posted to rec.aviation.soaring
Provided you study the operating manual and comply to any specific indications above all, in my experience the Rotax 505 allowed me to fly during the winter in northern Italy (take-off at little more than 0°C), and I was once able to go see the panorama from 5000 m AMSL with no problems (estimated 25°C below Zero). Of course the engine was producing reduced power and climb at altitude.
Starting the engine when cold-soaked after a prolonged wave flight is probably more trouble prone, but still possible. Battery performance matters, as well as engine conditions. Generally, having used the engine for self-launch or a test-run a few hours before, allows it to be still that little warmer and start more "reliably". Apply power progressively. Generally, less than a minute is enough, the engines have a small mass and warm up rapidly.
Currently I own a watercooled two-stroke SLG, and the manual mandates to warm the engine to 40°C before take-off. Takes maybe less than a minute while checking circuits and emergencies.
Aldo Cernezzi
www.voloavela.it
Old March 8th 17, 01:59 PM posted to rec.aviation.soaring
David Hart
I've been flying my DG800A with Rotax 505 in the cold weather of central PA recently and have the following recommendations. 1. Bundle up, rigging in the cold can be brutal. 2. Expect the batteries to lose charge more quickly, and for the engine extension/retraction to go a little more slowly than normal. 3. If CHT is below 0 Celsius before cranking, use the choke to start more reliably. 4. Read your aircraft manual regarding cold weather operation; some gelcoats may crack in extreme low temperatures. 6. If there is precipitation, make sure to check all your static ports/leading edges for snow and ice accumulation.
Old March 8th 17, 07:09 PM posted to rec.aviation.soaring
firsys
A squirt of campfuel or ether (quick start) greatly helps
start up.
JMF
Old March 8th 17, 08:20 PM posted to rec.aviation.soaring
JS
start up.
JMF
Here's my preferred brand. After all, it is what you're thinking or shouting at the time.
http://www.nulon.com.au/products/Aer...Engine_Starter
Old March 11th 17, 02:54 PM posted to rec.aviation.soaring
Paul Villinski
Thanks for the input -- has anyone had issues with carb icing on a self-launcher? Not something I have ever given any thought to. Specifically in reference to Tillotson carbs on the 505. There may be some longer engine runs involved while ferrying 45 miles to the local ridge.
Old March 11th 17, 03:18 PM posted to rec.aviation.soaring
I discovered my engines susceptibility to carb icing at about 400ft one cold winters morning, having spent the hour prior washing freezing dew slush off the wings. Who'da thunk it.
I'd assumed prior that it was all too tightly integrated for carb icing to be an issue.
Old March 11th 17, 10:47 PM posted to rec.aviation.soaring
Paul Villinski
And how did you handle it, turn back and land? Or resolve the situation in another way? Was engine performance compromised enough to threaten your safety?
Old March 12th 17, 04:25 AM posted to rec.aviation.soaring
The engine spluttered and stopped over about 5 seconds. I retracted the engine and did a very abbreviated circuit. My self launcher has a folding propellor and a single switch for up/down, it could have been a bad accident in a more complex self launcher (DG400 etc).
Cold Weather PreHeating Peter R. Owning 22 February 12th 07 07:57 PM
Cold weather starting. Mike Noel Owning 17 December 21st 05 03:24 AM
Warm Weather Pilots, Cold Weather Ops john smith Piloting 3 December 2nd 04 04:00 PM
Cold weather ops Happy Dog Piloting 13 February 6th 04 06:45 PM
Cold Weather Flying Jose Vivanco Owning 27 October 16th 03 11:27 AM
