Wanted: 80 mm Winter Mechanical Vario in Knots
Old March 17th 17, 02:20 PM posted to rec.aviation.soaring
Default Wanted: 80 mm Winter Mechanical Vario in Knots
Any used Winter Vario's out there?
Need the 3 1/8" (80 mm) vario for a Club Grob 103.
Contact: Tim Hanke
Adirondack Soaring
518-693-6849
Old March 17th 17, 04:08 PM posted to rec.aviation.soaring
I have a 80mm Sage that is in good working order installed in a flying glider. I will sell for $200 and I'll pay the US shipping.
Johnsinclair210(at)yahoo.com
Old March 18th 17, 10:41 PM posted to rec.aviation.soaring
All set. We got a couple.
Thanks John but we are allset !
Old March 22nd 17, 02:08 AM posted to rec.aviation.soaring
The previous vario I was looking at was ft/ min not knots. Anyone have an 80 mm (3 1/8") Winter Vario in Knots available ?
Contact: Tim Hanke
E-mail:
Ph: 518-693-6849
Old March 22nd 17, 02:28 AM posted to rec.aviation.soaring
Scott Williams
Contact: Tim Hanke
E-mail:
Ph: 518-693-6849
So, I understand a knot is equal to 101.2 feet per minute, is the requirement due to regulations or a non compromising desire for 'the right scale?
I completely understand either, Just wondering.
Scott.
Old March 22nd 17, 12:19 PM posted to rec.aviation.soaring
Scott,
Normally not a big deal but the flight manual for a Grob Twin clearly asks for a vario in knots.
Tim
Contact: Tim Hanke
E-mail:
Ph: 518-693-6849
Scott.
Old March 22nd 17, 12:26 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
right scale?
I've always assumed that using knots for airspeed and ROC was done so
that you can calculate you glide ratio without doing any units
conversion. Once that's done, divide your height by 6000, multiply by
glide ratio and thats your max possible range in NM.
I don't think its that easy if any other units are used for airspeed or
ROC.
Of course, this isn't so important now everybody has GPS navigation
systems that do it for you and draw glide amoebas on the screen.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
80mm mechanical vario wanted Frank Whiteley Soaring 3 July 4th 16 06:45 AM
Wanted: Used Winter Vario Tim Hanke Soaring 1 May 5th 15 05:18 PM
Winter mechanical vario Brian Bange[_2_] Soaring 1 February 15th 09 01:53 AM
Winter mechanical vario reading high Alan Meyer Soaring 13 April 13th 06 03:38 AM
Wanted: Used Mechanical Vario Tim Hanke Soaring 0 May 16th 05 06:35 PM
