Jet Sailplane Flies!
Old December 21st 03, 02:02 AM
Mhudson126
Default Jet Sailplane Flies!
All,
Please refer to the following link to see a video of the Silent moter-glider
with jet engine's attached. It is absolutely amazing watching a sailplane
doing a low pass with jet engines screaming, AND self-launching.
http://www.alisport.com/pag_ing/news.htm
Yes, the Jet's on the Silent ARE retractable.
For those of you who saw the pictures of the Ventus 2 moter-glider with Jet
engines attached, there is no way that thing self-launched. It does not count
unless it can self-launch! Here are the general numbers for those of you who
would like to do the math. The engines produce 34 pounds of thrust each, and
with a flying weight of about 1000 pounds, initial takeoff acceleration would
be a blistering 0.06 G's (About 1 knot a second). You would need a REALLY long
runway (See Edwards AFB) at sea level in order to get the thing in the air, IF
they could even produce enough thrust to beat the breaking point to start the
roll (Doubtful).
-Mitch Hudson
Old December 21st 03, 04:57 PM
Andy Durbin
(Mhudson126) wrote in message ...
All,
roll (Doubtful).
-Mitch Hudson
Don't try this site with Netscape 7.1 but it works ok with IE 5.5.
Andy
Old December 22nd 03, 12:05 PM
John Mason
It's a great sight and a great achievement. Practically though these
engines have a huge problem of poor fuel consumption. The consumption is
about 95lts/hour. A petrol self launcher will use 16lts/hr and will have a
21lt tank. To give the same duration the jet will need a very large and
heavy-when-full 120lt tank.
"Mhudson126" wrote in message
All,
moter-glider
Jet
count
who
and
would
long
air, IF
roll (Doubtful).
-Mitch
Hudson
Old December 22nd 03, 12:45 PM
Peter Seddon
Yes but what about the weight saving over the mechanics of the petrol
engine/prop etc.?
Peter S
DLA
Old December 22nd 03, 09:47 PM
John Mason
The advantage of the lightweight jet engine is totally eclipsed by the fuel
consumption problem.
A self launcher engine and prop and fuel tanks weighs 55-60kg with full fuel
tanks. They are already heavy enough and it would be better to go lighter
not heavier.
A pair of jet engines will weigh only 7kg but the fuel with tanks will be
about 95kg and so at 103kg is nearly double the weight surcharge,
furthermore as I implied before there is a big problem in finding enough
room to store 120lts. There may also be a weight and balance issue but if
the fuel were stored in the wing tanks instead of water ballast that would
be less of a problem but you would have little room left or weight reserve
for water then. You could treat the fuel as ballast and dump the fuel if
you chose to, it is pretty cheap stuff, cheaper than many brands of mineral
water.
If there existed a model fanjet engine and if it were to use say less than
half the fuel, a jet engine would begin to look like a good option.
"Peter Seddon" wrote in message
engine/prop etc.?
Peter S
DLA
Old December 22nd 03, 10:49 PM
Paul Remde
Not for me (too noisy) but interesting.
I wouldn't want all that heat pointed at my vertical stabilizer though.
Also, I imagine you'd have to let it cool down before retracting the
engines.
Paul Remde
All,
moter-glider
Jet
count
who
and
would
long
air, IF
roll (Doubtful).
-Mitch
Hudson
Old December 22nd 03, 11:02 PM
F.L. Whiteley
http://www.popsci.com/popsci/aviatio...563899,00.html
Interesting reading in the 01/2004 Popular Science and the approach to fuel
consumption.
Frank Whiteley
"John Mason" wrote in message
fuel
fuel
not heavier.
mineral
water.
engine/prop etc.?
Peter S
DLA
Old December 22nd 03, 11:53 PM
Peter Seddon
than
Not so long ago a jet engine of the size to fit into a model was just a
dream so perhaps a small turbo fan my soon be on the cards.
Peter S
DLA
Old December 23rd 03, 10:40 AM
JS
If the goal is soaring, whta is such amount of fuel needeed?
Fuel for few minutes to climb up to 500-1000 m, then fly soaring with only a
little amount of spare fuel to lenghten the final glide, if seems to be
getting short and no chance of convections. Maybe that 55-60 kg total weight
would be enough for engine and fuel, about half of it as emergency spare.
Noisy yes, and qoite flammable with burning heat gases.
There is a rocket fuel, peroxid, which generates adjustable thrust and
exhausts only hot water and oxygen, but it's unfortunately dangerosly
bioactive. Used to blond hair, too.
js
fuel
fuel
not heavier.
mineral
water.
engine/prop etc.?
Peter S
DLA
D.C. Air Guard Unit Flies New 737s Otis Willie Military Aviation 0 January 14th 04 11:12 PM
Sailplane Homebuilders Association workshop "report" Eric Greenwell Soaring 0 September 12th 03 06:07 AM
Electro-self-launching sailplane clement Soaring 5 September 12th 03 05:03 AM
Enola Gay flies into new A-bomb controversy Otis Willie Military Aviation 0 August 21st 03 09:10 PM
uh oh, Plane flies over Bush motorcade Mutts Piloting 38 July 29th 03 04:20 AM
