Cobra trailer brake heating up
Old April 3rd 17, 05:02 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Cobra trailer brake heating up
I adjusted the brakes on my Cobra trailer according to the directions from Cobra.
On the first test drive, the right brake drum got very hot in a few miles (about
240 deg F); the left brake drum got up to about 125 deg F.
Neither drum seems to be dragging when I jack up the wheel and spin it. I backed
off the right drum about 8-10 clicks, which reduced the temperature to 175 deg f
(but it was shorter drive). The brake handle still comes up to the correct position.
I'll back off the hot drum another 8 clicks, and see if it still gets hot, but I'm
wondering if I'm missing something here. Does anyone know why it's getting so hot
if it isn't dragging?
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old April 3rd 17, 09:24 AM posted to rec.aviation.soaring
David Salmon[_3_]
from
Cobra.
(about
backed
175
deg f
correct
position.
hot,
but I'm
getting
so hot
me)
Just a couple of thoughts.
Are the wheel bearings adjusted correctly and greased?
On the brake rod linkage, is the 1mm gap there with the brake off?
Dave
Old April 3rd 17, 04:22 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
If your trailer is newer-2000 or so, it probably has the sealed bearings. They can fail, and heat the drum. Are you checking the hub temp, or the drum rim temp? Remove the drum and inspect mechanism of brakes--may be stuck and not backing off.
If it heats to high, too long, you can anneal the axle and it will break off! Find the problem.
Old April 4th 17, 05:02 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Hartley Falbaum wrote on 4/3/2017 7:22 AM:
It does have the sealed bearings. I'm checking the temperature at the drum rim.
I'll pull the drum and hope I see something that's easy to fix!
Old April 4th 17, 05:08 AM posted to rec.aviation.soaring
Have you checked the overrun mechanism in the tongue, especially the damper? Also the large bushings in the outer tube in which the inner tube slides can get dry (there are grease fittings). The inner tube can rust/corrode. And the bushings themselves (some kind of plastic) can seem to swell, causing binding.
Also the cable actuators inside their housings can rust, binding and causing the brake shoes to not release. You can remove the assemblies at both ends and then add lubricant. Spinning the cable inside the guide can help free things up, also.
If you replaced the brake shoes recently, make sure you got the identical set and that they were installed in the correct orientation so they don't "self energize" to the point where they hang up.
The Alko surge brake works well when everything is in order but there are many things that can go wrong--with disastrous results.
Chip Bearden
Old April 4th 17, 05:36 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
wrote on 4/3/2017 8:08 PM:
Also the cable actuators inside their housings can rust, binding and causing the brake shoes to not release. You can remove the assemblies at both ends and then add lubricant. Spinning the cable inside the guide can help free things up, also..
The overrun mechanism is working properly. I'll check the cable actuators when I
take the drum off tomorrow. The shoes are original, and appear to have plenty of
lining when I look through the little hole in the backing plate, but I'll know for
sure with the drum off.
Old April 5th 17, 10:55 PM posted to rec.aviation.soaring
It's also possible there are​ brake hardware problem. The tiny areas where the brake shoes rest on the backing plate should have a small amount of high-temp grease (don't want any on the friction material itself or the drum). And the return springs can lose some strength, especially if the brakes have overheated, and fail to pull the brake shoes away from the drums.. There are also other links that can get sticky and cause problems. Most of these things don't occur but when you're looking for a reason for dragging brake shoes, it's another possibility.
Chip Bearden
Old April 16th 17, 02:24 PM posted to rec.aviation.soaring
John Carlyle
Eric,
what did you find that caused your brake problem? I'm going to be adjusting my 2000 Cobra trailer brakes soon, and would appreciate any hints you could give.
-John, Q3
Old April 20th 17, 05:50 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Carlyle wrote on 4/16/2017 5:24 AM:
Eric,
-John, Q3
I decided I'd rather to other things than work on a trailer, so today I took it to
the mechanic that does my motorhome repairs. Didn't find anything external, so
tomorrow they'll pull the hubs. I'll let you know.
Old August 13th 18, 08:44 PM posted to rec.aviation.soaring
Bumping this thread to see what Eric found last year.
My Cobra brake jammed on after a hard stop on the way home from Midlothian last week. Couldn't free it up so disconnected the brake cables at the center brake rod. That freed up the wheels immediately so I drove home. Seemed to stay jammed until I came up the steep driveway. Now it's free, with no indication what might have been wrong. The inner sliding tube and bushings were lubed and moved freely. The brakes and cables were fine; the wheels turned freely after I disconnected the cables even though the tongue was still jammed in the collapsed position.
One odd thing: the lever that comes out of the lower part of the tongue that pulls the brake rod couldn't be tapped loose. No surprise since the inner tube was fully collapsed and thus actuating this lever. But on the way home, I stopped again: tongue was still collapsed but this time when I tapped the lever, it came loose and moved freely. I'm just getting into it now to see what might be amiss but has anyone had this problem?
Chip Bearden
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 03:42 PM
Source for Cobra Trailer Brake Shoes Chip Bearden[_2_] Soaring 1 September 22nd 10 03:48 AM
cobra trailer brake lever gas strut problem - solved Frank[_1_] Soaring 1 April 3rd 09 07:08 AM
cobra trailer brake lever gas strut failure? Frank[_1_] Soaring 11 March 31st 09 09:59 PM
Older Cobra trailer brake oscillation Brian Bange[_2_] Soaring 9 March 10th 09 08:41 PM
