I want to ask you folks a question: why isn't there a glider where
the pilot flies face-down? The Wrights did it, the Horten (?) wing, and hang gliders are about the only thing you can fly facing the earth. I don't see why a sailplane couldn't be flown that way, but no designers appear to even consider the possibility. Ideas? GillCouto.com |
breaking my neck trying to look up?? the hang gliders have wing above their
heads and can't see up... BT "Gill Couto" wrote in message news:gusHb.24528$J77.3186@fed1read07... I want to ask you folks a question: why isn't there a glider where the pilot flies face-down? The Wrights did it, the Horten (?) wing, and hang gliders are about the only thing you can fly facing the earth. I don't see why a sailplane couldn't be flown that way, but no designers appear to even consider the possibility. Ideas? GillCouto.com |
maybe because the Wrights didn't fly for hours at a time, and only had to
hold their heads up for a matter of minutes? "Gill Couto" wrote in message news:gusHb.24528$J77.3186@fed1read07... I want to ask you folks a question: why isn't there a glider where the pilot flies face-down? The Wrights did it, the Horten (?) wing, and hang gliders are about the only thing you can fly facing the earth. I don't see why a sailplane couldn't be flown that way, but no designers appear to even consider the possibility. Ideas? GillCouto.com |
Gill Couto wrote in message news:gusHb.24528$J77.3186@fed1read07...
I want to ask you folks a question: why isn't there a glider where the pilot flies face-down? The Wrights did it, the Horten (?) wing, and hang gliders are about the only thing you can fly facing the earth. I don't see why a sailplane couldn't be flown that way, but no designers appear to even consider the possibility. Ideas? GillCouto.com Comfort (neck) Saftey (see above) Visability (see below?) Geezers have a hard time holding their heads up -Head down and locked |
I want to ask you folks a question: why isn't there a glider where the pilot flies face-down? The Wrights did it, the Horten (?) wing, and hang gliders are about the only thing you can fly facing the earth. I don't see why a sailplane couldn't be flown that way, but no designers appear to even consider the possibility. Ideas? There's also crash survivability to consider. A head first crash into an object doesn't sound good. Feet and legs are relatively expendable compared to the head. One might ask, why lay that way? I assume you mean to imply that a fuselage with a smaller cross-section, hence less drag, could then be employed. This has sort of been done in the HP-18 series of gliders. In the HP-18 one lays almost flat on one's back, fet forward of course, with the head tilted upward somewhat using a head rest. The HP-18 fuse is pretty short compared to most. Comfort can be an issue, or so I'm told. But to be fair, many say they like it just fine. -Doug |
Technical soaring ( the OSTIV magazine ) July 2002. pg 89.
The article suggests that the prone ( face down and forward ) position may actually provide added safety rather than less safety when an analysis of aircraft accidents is made. However upward visibility would be a problem ( unless there was a horizontal mirror in front of and below the pilots line of forward sight ) Keeping your head up could be fun after 8 hours! Most of this is in reference to the Exulans ultra-light tailess sailplane. http://members.tripod.com/~diomedes/exulans/ Ian |
In message , tango4
writes Technical soaring ( the OSTIV magazine ) July 2002. pg 89. The article suggests that the prone ( face down and forward ) position may actually provide added safety rather than less safety when an analysis of aircraft accidents is made. However upward visibility would be a problem ( unless there was a horizontal mirror in front of and below the pilots line of forward sight ) Keeping your head up could be fun after 8 hours! Most of this is in reference to the Exulans ultra-light tailess sailplane. http://members.tripod.com/~diomedes/exulans/ Ian During the second world war the Germans experimented with gliders to shoot down bombers. At least one of these had a prone position. The pilot had a chin rest to take the weight of his head. Robin -- Robin Birch |
Sailplanes spend a lot of time circling in thermals with an appreciable bank
angle, 30 degrees or more. It is important for collision/terrain avoidance to look in the direction of the turn, which is always upwards relative to the pilot's position. Moreover, pilots don't look down as often as non-pilots would think. Most of the time they look more or less at the horizon when flying visually, with occasional glances at the instrument panel -- which in normal cockpits is just below the horizon. (How comfortable would it be to lie prone on the living-room floor to watch TV?) Pilots must also look to the left and right as well as ahead. If you are sitting up, you retain much of the horizon in your peripheral view as you turn your head. Not so when you are prone. Mike Yankee (Address is munged to thwart spammers. To reply, delete everything after "com".) |
Doug Hoffman wrote in message ...
One might ask, why lay that way? I assume you mean to imply that a fuselage with a smaller cross-section, hence less drag, could then be employed. This has sort of been done in the HP-18 series of gliders. In the HP-18 one lays almost flat on one's back, fet forward of course, with the head tilted upward somewhat using a head rest. The HP-18 fuse is pretty short compared to most. Comfort can be an issue, or so I'm told. But to be fair, many say they like it just fine. -Doug And don't forget the Siren Edelweiss C30S \ / \./ ----------------(o)----------------- u |
| Thread Tools | |
| Display Modes | |
| But, I'm a skilled professional | [email protected] | Piloting | 10 | December 2nd 04 06:01 AM |
| definition of "dual controls" | Lee Elson | Instrument Flight Rules | 4 | April 24th 04 03:58 PM |
