https://en.wikipedia.org/wiki/Mikoyan-Gurevich_MiG-23
The Mikoyan-Gurevich MiG-23 (Russian: ?????? ? ??????? ???-23; NATO reporting name: Flogger) is a variable-geometry fighter aircraft, designed by the Mikoyan-Gurevich design bureau in the Soviet Union. It is considered to belong to the Soviet third-generation jet fighter category, along with similarly aged Soviet fighters such as the MiG-25 "Foxbat". It was the first attempt by the Soviet Union to design look-down/shoot-down radar and one of the first to be armed with beyond visual range missiles. Production started in 1970 and reached large numbers with over 5,000 aircraft built. Today the MiG-23 remains in limited service with some export customers. The basic design was also used as the basis for the Mikoyan MiG-27, a dedicated ground-attack variant. Among many minor changes, the MiG-27 replaced the MiG-23's nose-mounted radar system with an optical panel holding a laser designator and a TV camera. The MiG-23's predecessor, the MiG-21 (NATO reporting name "Fishbed"), was fast and agile, but limited in its operational capabilities by its primitive radar, short range, and limited weapons load (restricted in some aircraft to a pair of short-range R-3/K-13 (AA-2 "Atoll") air-to-air missiles). The MiG-23 was to be a heavier, more powerful machine designed to remedy these deficiencies, and match Western aircraft like the F-4 Phantom. The new fighter was to feature a totally new S-23 sensor and weapon system capable of firing beyond-visual-range (BVR) missiles. Role Interceptor/Fighter (M series) Fighter-bomber (B series) National origin Soviet Union Manufacturer Mikoyan-Gurevich First flight 10 June 1967 Introduction 1970 Status Limited service Primary users Soviet Air Force (historical) Syrian Air Force Indian Air force (historical) Bulgarian Air Force (historical) See Operators below Produced 1967–1985 Number built 5,047 Variants Mikoyan MiG-27 Western and Russian aviation historians usually differ in respect to combat record for their military vehicles and doctrines part due to the bias in favor of their respective national industries and academies. They also usually accept claims going along with their respective political views since usually many conflicting and contradictory reports are written and accepted by their respective historians. Before recent years, with widespread use of hand portable cameras, little pictorial evidence could be published about specific losses and victories of the different combat systems, with a limited number of losses and victories confirmed by both parties. Western sources, generally attribute a very limited number of confirmed air-to-air victories to the MiG-23 while reporting a higher number of MiG-23s downed mostly by Israeli Air Force in 1982, while Russian sources generally decrease the number of losses and increase the number of inflicted kills bringing the air-to-air kill to loss ratio to around parity. Soviet MiG-23s were used over Afghanistan. Some of them were claimed shot down. Soviet and Afghan MiG-23s and Pakistani F-16s clashed a few times during the Soviet war in Afghanistan from 1987. Two MiG-23 were claimed shot down in air to air fight by Pakistani F-16s when crossing the border while one F-16 was shot down on 29 April 1987. Pakistani[citation needed] and Western[10] sources consider it a friendly fire incident but the Soviet-backed Afghan government of the time claimed that Soviet aircraft downed the Pakistani F-16 – a claim that The New York Times and the Washington Post also reported. According to a Russian version of the event, the F-16 was shot down when Pakistani F-16s encountered Soviet MiG-23MLDs. Soviet MiG-23MLD pilots, while on a bombing raid along the Pakistani-Afghan border, reported being attacked by F-16s and then seeing one F-16 explode. It could have been downed by gunfire from a MiG whose pilot did not report the kill, because Soviet pilots were not allowed to attack Pakistani aircraft without permission Specifications (MiG-23MLD Flogger-K) General characteristics Crew: One Length: 16.70 m (56 ft 9.5) Wingspan: Spread, 13.97 m (45 ft 10 in) Height: 4.82 m (15 ft 9.75 in) Wing area: 37.35 m² spread, 34.16 m² swept (402.05 ft² / 367.71 ft²) Empty weight: 9,595 kg (21,153 lb) Loaded weight: 15,700 kg (34,612 lb) Max. takeoff weight: 18,030 kg (39,749 lb) Powerplant: 1 × Khatchaturov R-35-300 afterburning turbojet, 83.6 kN dry, 127 kN afterburning (18,850 lbf / 28,700 lbf) Performance Maximum speed: Mach 2.32, 2,445 km/h at altitude; Mach 1.14, 1,350 km/h at sea level (1,553 mph / 840 mph) Range: 1,150 km with six AAMs combat, 2,820 km ferry (570 mi / 1,750 mi) Service ceiling: 18,500 m (60,695 ft) Rate of climb: 240 m/s (47,245 ft/min) Wing loading: 420 kg/m² (78.6 lb/ft²) Thrust/weight: 0.88 Armament 1× Gryazev-Shipunov GSh-23L 23 mm cannon with 200 rounds Two fuselage, two wing glove, and two wing pylons for up to 3,000 kg (6,610 lb) of stores, including: R-23/24 (AA-7 "Apex") R-60 (AA-8 "Aphid") also, upgraded aircraft may carry: R-27 (AA-10 "Alamo") R-73 (AA-11 "Archer") R-77 (AA-12 "Adder") According to the MiG-23ML manual, the MiG-23ML has a maximum sustained turn rate of 14.1 deg/sec and a maximum instantaneous turn rate of 16.7 deg/sec. The MiG-23ML accelerates from 600 km/h (373 mph) to 900 km/h (559 mph) in 12 seconds at the altitude of 1000 meters. The MiG-23 accelerates at the altitude of 1 km from 630 km/h (391 mph) to 1300 km/h (808 mph) in 30 seconds and at the altitude of 10–12 km will accelerate from Mach 1 to Mach 2 in 160 seconds. * |
| Thread Tools | |
| Display Modes | |
| Mikoyan-Gurevich MiG-21 pics [18/21] - Mikoyan-Gurevich_MiG-21PF_USAF.jpg (1/1) | Miloch | Aviation Photos | 0 | August 22nd 16 04:24 AM |
| Mikoyan-Gurevich MiG-21 pics [17/21] - Mikoyan-Gurevich_MiG-21bis,_Hungary_-_Air_Force_AN0740836.jpg (1/1) | Miloch | Aviation Photos | 0 | August 22nd 16 04:24 AM |
| Mikoyan-Gurevich MiG-21 | Miloch | Aviation Photos | 0 | August 22nd 16 04:09 AM |
| Mikoyan-Gurevich MiG-19 pics [4/8] - Mikoyan-Gurevich_MiG-19S_at_the_National_Museum_of_the_United_States_Air_Force.JPG (1/1) | Miloch | Aviation Photos | 0 | August 21st 16 07:48 AM |
| Mikoyan-Gurevich MiG-19 | Miloch | Aviation Photos | 0 | August 21st 16 07:40 AM |
