Is it acceptable practice to put lead in a gliders tail to counter the weight
of a large pilot? David R. |
I've heard of it being done
"Flyhighdave" wrote in message ... Is it acceptable practice to put lead in a gliders tail to counter the weight of a large pilot? David R. -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
Flyhighdave wrote:
Is it acceptable practice to put lead in a gliders tail to counter the weight of a large pilot? David R. Stay within the aft CG limit ;-) |
any weight added to the tail.. by means other than factory supplied ballast
weights.. should be noted in the forms.. and the min/max placarded weight limits in the cockpit updated to reflect the change.. you have effectively changed the "empty" weight and CG of the glider. BT "Flyhighdave" wrote in message ... Is it acceptable practice to put lead in a gliders tail to counter the weight of a large pilot? David R. |
weight of a large pilot? David R. I flew a twin commander (small twin power plane) which was overly forward C.G. The owner had removed two large 1960's radios from the mid/tail. Our A&P simply installed weights in the tailcone. Personally, I would have an A&P do this kind of installation in a glider as well. I would also find others who have done so. I know the Sparrowhawk seems to have three different metals for interchangable tail stabilizer crossmembers. Perhaps someone could fabricate some replacement tail part from a heavier metal? |
In the case of an ASW 24 My friend who weighs 230 lb is well over six feet has a lead weight of six kilo's or 13.2 lb. installed in the fin. Each glider has or at least should have provisions to install this type of weight to make sure the glider flies within the required C of G. Udo Is it acceptable practice to put lead in a gliders tail to counter the weight of a large pilot? David R. |
It's an accepted and widespread practice to put lead
in the tail to get the C of G where you want it. However, be aware that although a glider with a heavy pilot and tail ballast may well have the C of G in the same place as one with a light pilot and no ballast, its spinning behaviour may well be quite different due to the greater rotational inertia. In general a glider with a heavy pilot and tail ballast will have a greater tendancy for the spin to flatten, and recovery may be more difficult or at least slower. Gliders with tail ballast, particularly if carried fairly high up in the fin, are also more likely to suffer damage in ground loops. At 08:42 03 January 2004, Udo Rumpf wrote: In the case of an ASW 24 My friend who weighs 230 lb is well over six feet has a lead weight of six kilo's or 13.2 lb. installed in the fin. Each glider has or at least should have provisions to install this type of weight to make sure the glider flies within the required C of G. Udo Is it acceptable practice to put lead in a gliders tail to counter the weight of a large pilot? David R. |
The other thing to consider, beside the sensible advice
below is:- Is the glider able to carry any more weight,over and above that of the pilot. Many earlier generation glass gliders Cirrus,Asw15.Libelle,Astir, the max cockpit weight is limited by the max all up weight, resulting in cockpit max weights of much less than 110kg, The addition of lead in the tail to adjust the C/G would only result in reducing cockpit load even more At 09:00 03 January 2004, Chris Rollings wrote: It's an accepted and widespread practice to put lead in the tail to get the C of G where you want it. However, be aware that although a glider with a heavy pilot and tail ballast may well have the C of G in the same place as one with a light pilot and no ballast, its spinning behaviour may well be quite different due to the greater rotational inertia. In general a glider with a heavy pilot and tail ballast will have a greater tendancy for the spin to flatten, and recovery may be more difficult or at least slower. Gliders with tail ballast, particularly if carried fairly high up in the fin, are also more likely to suffer damage in ground loops. At 08:42 03 January 2004, Udo Rumpf wrote: In the case of an ASW 24 My friend who weighs 230 lb is well over six feet has a lead weight of six kilo's or 13.2 lb. installed in the fin. Each glider has or at least should have provisions to install this type of weight to make sure the glider flies within the required C of G. Udo Is it acceptable practice to put lead in a gliders tail to counter the weight of a large pilot? David R. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 06:39 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Effect of Light Sport on General Aviation | Gilan | Home Built | 17 | September 24th 03 07:11 AM |
| The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 23rd 03 12:01 AM |
