Arado Ar 234
Old April 1st 17, 04:00 PM posted to alt.binaries.pictures.aviation
Miloch
Default Arado Ar 234
https://en.wikipedia.org/wiki/Arado_Ar_234
The Arado Ar 234 Blitz (English: lightning) was the world's first operational
jet-powered bomber, built by the German Arado company in the closing stages of
World War II.
Produced in very limited numbers, it was used almost entirely in the
reconnaissance role, but in its few uses as a bomber it proved to be nearly
impossible to intercept. It was the last Luftwaffe aircraft to fly over Britain
during the war, in April 1945.
In late 1940, the Reich Air Ministry (German: Reichsluftfahrtministerium,
abbreviated RLM) offered a tender for a jet-powered high-speed reconnaissance
aircraft with a range of 2,156 km (1,340 mi). Arado was the only company to
respond, offering their E.370 project, led by Professor Walter Blume. This was a
high-wing conventional-looking design with a Junkers Jumo 004 engine under each
wing.
Arado estimated a maximum speed of 780 km/h (480 mph) at 6,000 m (20,000 ft), an
operating altitude of 11,000 m (36,000 ft) and a range of 1,995 km (1,240 mi).
The range was short of the RLM request, but they liked the design and ordered
two prototypes as the Ar 234. These were largely complete before the end of
1941, but the Jumo 004 engines were not ready, and would not be ready until
February 1943. When they did arrive they were considered unreliable by Junkers
for in-flight use and were cleared for static and taxi tests only.
Flight-qualified engines were finally delivered, and the Ar 234 V1 made its
first flight on 30 July 1943 at Rheine Airfield (presently Rheine-Bentlage Air
Base).
By September, four prototypes were flying. The second prototype, Arado Ar 234
V2, crashed on 2 October 1943 at Rheine near Münster after suffering a fire in
its port wing, failure of both engines and various instrumentation failures. The
aircraft dived into the ground from 1,200 m (3,900 ft), killing pilot
Flugkapitän Selle. The eight prototype aircraft were fitted with the original
arrangement of trolley-and-skid landing gear, intended for the planned
operational, but never-produced Ar 234A version.
The sixth and eighth of the series were powered with four BMW 003 jet engines
instead of two Jumo 004s, the sixth having four engines housed in individual
nacelles, and the eighth flown with two pairs of BMW 003s installed within
"twinned" nacelles underneath either wing. These were the first four-engine jet
aircraft to fly. The twin-Jumo 004 powered Ar 234 V7 prototype made history on 2
August 1944 as the first jet aircraft ever to fly a reconnaissance mission,
flown by Erich Sommer.
Role
Reconnaissance jet bomber
Manufacturer
Arado Flugzeugwerke
Designer
Walter Blume
First flight
15 June 1943
Introduction
September 1944
Status
Retired
Primary user
Luftwaffe
Number built
214
The few 234Bs entered service in autumn and impressed their pilots. They were
fairly fast and completely aerobatic. The long takeoff runs led to several
accidents; a search for a solution led to improved training as well as the use
of twin HWK-built, jettisonable liquid fueled monopropellant Starthilfe
pioneering RATO units, one mounted under each outer wing. The Jumo 004 engines
were always the real problem; they suffered constant flameouts and required
overhaul or replacement after about 10 hours of operation.
The most notable use of the Ar 234 in the bomber role was the attempt to destroy
the Ludendorff Bridge at Remagen. Between 7 March, when it was captured by the
Allies, and 17 March, when it finally collapsed, the bridge was continually
attacked by Ar 234s of III/KG 76 carrying 1,000 kg (2,200 lb) bombs. The
aircraft continued to fight in a scattered fashion until Germany surrendered on
8 May 1945. Some were shot down in air combat, destroyed by flak, or "bounced"
by Allied fighters during takeoff or on the landing approach, as was already
happening to Messerschmitt Me 262 jet fighters. Most simply sat on the airfields
awaiting fuel that never arrived.
Overall from mid-1944 until the end of the war a total of 210 aircraft were
built. In February 1945, production was switched to the C variant. It was hoped
that by November 1945 production would reach 500 per month.
Specifications (Ar 234B-2)
General characteristics
Crew: 1
Length: 12.64 m (41 ft 6 in)
Wingspan: 14.41 m (47 ft 3 in)
Height: 4.29 m (14 ft 1 in)
Wing area: 26.4 m2 (284 sq ft)
Empty weight: 5,200 kg (11,464 lb)
Max takeoff weight: 9,800 kg (21,605 lb)
Powerplant: 2 × Junkers Jumo 004B-1 axial flow turbojet engines, 8.83 kN (1,990
lbf) thrust each
Powerplant: 2 × Walter HWK 109-500A-1 Starthilfe liquid fuelled jettisonable
JATO rocket pods, 4.905 kN (1,103 lbf) thrust each (optional)
Performance
Maximum speed: 742 km/h (461 mph; 401 kn) at 6,000 m (20,000 ft)
Cruise speed: 700 km/h (435 mph; 378 kn) at 6,000 m (20,000 ft)
Range: 1,556 km (967 mi; 840 nmi) with 500 kg (1,100 lb) bomb load
Service ceiling: 10,000 m (33,000 ft)
Rate of climb: 13 m/s (2,600 ft/min)
Armament
Guns: 2 × 20 mm MG 151 cannon in tail firing to the rear (installed in
prototypes only; never used in military service)
Bombs: up to 1,500 kg (3,309 lb) of disposable stores on external racks
Arado Ar 232 pics 2 [7/7] - Arado-Ar-232-8.jpg (1/1) Miloch Aviation Photos 0 March 30th 17 03:11 PM
Arado Ar 232 pics 2 [3/7] - Arado Ar 232.jpg (1/1) Miloch Aviation Photos 0 March 30th 17 03:11 PM
Arado Ar 232 pics 2 [2/7] - Arado Ar 232 b.jpg (1/1) Miloch Aviation Photos 0 March 30th 17 03:11 PM
Arado Ar 232 pics 2 [1/7] - Arado Ar 232 3.jpg (1/1) Miloch Aviation Photos 0 March 30th 17 03:11 PM
Arado Ar 232 pics 1 [10/10] - Arado Ar 232 2.jpg (1/1) Miloch Aviation Photos 0 March 30th 17 03:10 PM
