Solvent save for markings
Old January 21st 04, 04:09 AM
chris
Default Solvent save for markings
Anyone know what solvent is safe to use on the markings on my glider?
There are some spots to be removed on the red nose markings.
I've removed some old lettering off the gelcoat with Acetone and
lacquer thinner, so I know those will destroy the markings. The
lettering may be lacquer.
Chris
Old January 22nd 04, 01:35 AM
HL Falbaum
If you are trying to clean the painted areas, try a cleaner/wax such as the
Wx Block/Seal system, or Stahlfix. Otherwise 3M adhesive remover is mostly
Benzine and works well.
Always try a little spot first!
Hartley Falbaum
"chris" wrote in message
m...
Chris
FS 2004 with multiple monitors - how to save settings? Horst Walter Simulators 5 December 8th 04 02:29 PM
Cant save the downloaded real weather Mikker Simulators 1 September 16th 04 03:08 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 04:33 PM
Yokota squadron newly equipped to save lives Otis Willie Military Aviation 0 November 6th 03 11:51 PM
GPS Visualizer update: now you can "save your work" Adam Schneider Soaring 0 July 28th 03 10:26 PM
