LNav "meter" problem
Old May 16th 17, 03:10 PM posted to rec.aviation.soaring
Kurt[_3_]
Default LNav "meter" problem
I have a LNav / meter that has worked fine in the past. Sunday the meter pegged out at 10 knots and stayed there. I cycled the LNav a few times and it kept doing the same thing. Does anyone have experience with this, and if so, what was the fix? The LNav itself seems to be fine.
Thanks
Kurt
Old May 16th 17, 03:56 PM posted to rec.aviation.soaring
JS
Thanks
Kurt
Kurt, can you zero the meter using the calibration page? If not, I think your LNAV needs to visit Gary Kammerer. But the instrument is so old that parts if needed might be a problem.
(cut/paste and edit from ClearNav website below)
Gary Kammerer - Independent Contractor
Cambridge Service/Support
144 Daltons Rd
Waterbury, VT 05676
Gary Kammerer - Customer Service
Gary at ClearNav dot net
802-882-8530
Old May 16th 17, 05:58 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Thanks
Kurt
We had a similar problem with our Club's Discus and LNav. Gary fixed it--don't know what he did!
Old May 17th 17, 02:03 AM posted to rec.aviation.soaring
Kurt[_3_]
Thanks
Kurt
Thanks. I will look at the calibration page, and if that does not fix it, I will send it in for repair.
Old May 17th 17, 04:34 AM posted to rec.aviation.soaring
Ian Reekie[_2_]
Default LNav
Its always worth replacing the internal lithium button battery and then
reseting internal parameters back to factory default.(Page 20 of the
version 5.8 manual, followed by re-entering your polars etc)
Apparently when the battery gets low, some of the stored internal parameter
values in battery backed up RAM can get corrupted and "strange things" can
start to happen.
Replacing the battery and doing this factory reset has fixed my LNAV in the
past.
(This was a tip given to me by the Dickie Feakes the UK service agent.)
meter=
an=
and=
=20
Thanks
=20
Kurt
I=
LNav G-meter. Bob 7U Soaring 1 August 14th 09 07:07 PM
LPV versus LNAV/VNAV versus LNAV+V Wyatt Emmerich[_2_] Instrument Flight Rules 6 December 17th 07 01:38 AM
For sale: DG-600 17-meter and 15-meter wingtips Lars Peder Hansen Soaring 0 January 21st 07 06:18 PM
LNAV preferable over LNAV/VNAV [email protected] Instrument Flight Rules 4 October 16th 05 06:34 PM
LNav Gregg Leslie Soaring 1 May 22nd 05 06:23 AM
