In-Flight CG Calculation
Old May 29th 17, 02:20 PM posted to rec.aviation.soaring
Default In-Flight CG Calculation
Just curious if current technology could easily/cheaply support this calculation ... using a couple of accelerometers ... kk
Old May 29th 17, 02:28 PM posted to rec.aviation.soaring
John Carlyle
Getting tired of leveling, measuring, weighing and calculating, KK?
John, Q3
Old May 29th 17, 04:21 PM posted to rec.aviation.soaring
John, Q3
We don't do it all that often - so not really ... but it is a little bit of a process when you do have to ... so just wondering.
Old May 29th 17, 04:28 PM posted to rec.aviation.soaring
Matt Herron Jr.
are you concerned with dumping water and changing your CG?
Old May 29th 17, 04:47 PM posted to rec.aviation.soaring
Hi Matt ... not really, the factory numbers and methods we all use are sound and time tested ... and I just used these methods to calculate CGs for an empty ship - and with pilot and chute - just to know 'exactly' where the CG is located. I was just curious if CG could be calculated in flight ... using hardware/electronics that are available today. Just a question on a rainy afternoon in Delaware. kk
Old May 29th 17, 08:55 PM posted to rec.aviation.soaring
Roy Garden
There is a simple in flight test used with RC gliders.
Some of which are getting to be quite big these days and a subsection of
which fly faster than 500 mph (up hill, into wind, that was measured at)
So, probably, has some application in our sport.
Fly at whatever speed you are normally trimmed at and put the glider
into a dive (not particularly steep, say 30 deg nose down) and let the
glider do what it wants from there. (staying below Va or Vne depending
on conditions)
If the glider stays at that angle an RC glider has it's CofG perfect (for
us
that means our CofG is a bit too far back as we need more stability in
pitch than the RC gliders)
If the glider pitches down and increases the dive, your CofG is too far
back (flying surfaces are keeping the nose down and their effect
becomes more pronounced as speed builds)
If the glider recovers back to flat n level then the CofG on ours is about
right, on an RC glider it's a bit too far forward.
The other check to make before you do this: note where your trimmer is
in normal flight, after landing put the trimmer back there and look at the
elevator. Ideally, when your CofG is right, your elevator should be in line
with the horizontal stab at "Normal" trim (it probably isn't as your CofG
will be a bit forward to give the glider longitudinal stability)
So, the RC glider test will show where your inflight CofG is (note, your
center of pressure will move relative to your CofG depending on speed)
Modern gliders are designed to be stable.
Older gliders too (but usually not so well)
A slightly forward CofG gives you stability
A very forward CofG gives you lots of drag.
A rearward CofG gives your wife hope for the next husband to be better .
Old May 29th 17, 09:48 PM posted to rec.aviation.soaring
Ehhhh...that can work, but.........doesn't help to determine CG envelope when your butt is in the glider. Static on the ground (done properly) tells you where you are before getting in.
-Centered CG is nice.
-Forward CG can be good for training/low timers. If you don't pay attention to pitch and relax on the stick the glider will speed up, staying away from stall.
-For XC, sit on the ground, mark the stick where the elevator is neutral to the stab, fly, see where the stick is flying a constant speed used for XC, change weight (CG) until the glider flies hands off at the required speed (stick relative to mark made before on neutral controls). This is usually an aft CG.
Yes, I have accidentally flown a CG out the backside before....once (ASW-20). Over the top spin entries when doing zoomies into thermals told me something was not right. The glider owner (flying tow at that time and saw a couple spins) asked over the radio, "spin much Chuck?!?!".
Old May 29th 17, 10:55 PM posted to rec.aviation.soaring
Matt Herron Jr.
May I humbly recommend a C of G program I wrote specifically for gliders? It's called SeeG and is available he http://www.glideplan.com/styled-2/page12/index.html
Lots of discovery tools for adding moments, playing with water, charting effects of changing CG, etc.
Matt
Old May 30th 17, 06:04 AM posted to rec.aviation.soaring
JS
Hi Matt ... not really, the factory numbers and methods we all use are sound and time tested ... and I just used these methods to calculate CGs for an empty ship - and with pilot and chute - just to know 'exactly' where the CG is located. I was just curious if CG could be calculated in flight .... using hardware/electronics that are available today. Just a question on a rainy afternoon in Delaware. kk
Matt
Matt, you beat me to it.
Was going to ask Kilo Kilo the millennial question:
"Don't they make an app for that?"
Old May 30th 17, 01:28 PM posted to rec.aviation.soaring
Matt
Hey ... I'm not one of those millennials ... I'm a grumpy senior citizen .... :-)
302 wind calculation 5Z Soaring 1 March 26th 10 11:56 AM
302 wind calculation AK Soaring 0 March 26th 10 02:47 AM
flight computer calculation Tim General Aviation 1 April 26th 05 10:40 AM
Three leg GS to TAS calculation Mike Rapoport Owning 21 September 12th 04 04:37 AM
The "Complex" TAS calculation Arnold Pieper Soaring 2 December 14th 03 12:22 PM
