Flarm Range Analysis
Old June 5th 17, 11:17 PM posted to rec.aviation.soaring
Dan Marotta
Default Flarm Range Analysis
As a relatively new user of Flarm, I'm asking opinions of the results
I'm getting. Mine is a Power Flarm portable mounted to the glare shield
of my Stemme and has both Flarm A and B antennae and an ADS-B antenna.
Here's a link to my analysis on a flight yesterday with plenty of Flarm
targets: Flarm Range Analysis
https://www.dropbox.com/s/ny2ncdlua10jzt2/Flarm%20Range%20Analysis.jpg?dl=0.
Comments appreciated.
Dan, 5J
Old June 5th 17, 11:22 PM posted to rec.aviation.soaring
Matt Herron Jr.
results I'm getting.Â* Mine is a Power Flarm portable mounted to the
glare shield of my Stemme and has both Flarm A and B antennae and an
ADS-B antenna.Â* Here's a link to my analysis on a flight yesterday
with plenty of Flarm targets:Â* Flarm
Range Analysis.
Dan, 5J
looks very acceptable. better than a lot I have seen. range at your 6 is great.
Old June 6th 17, 12:52 AM posted to rec.aviation.soaring
Dan Marotta
Thanks! All of the antennae are mounted on top of the glare shield and
I was concerned about coverage below and behind.
results I'm getting. Mine is a Power Flarm portable mounted to the
ADS-B antenna. Here's a link to my analysis on a flight yesterday
with plenty of Flarm targets: Flarm
Range Analysis.
Dan, 5J
Dan, 5J
Old June 8th 17, 03:21 AM posted to rec.aviation.soaring
Very good reception compared to most of what I've seen. I would love to see a photo or detailed description of your antenna layout, in particular the location, orientation, and separation of the FLARM A and B antennas. I assume the former is mounted on the portable box itself.
Chip Bearden
Old June 8th 17, 03:55 AM posted to rec.aviation.soaring
I utilize the Flarm range analysis tool a few times each season to make sure that my antenna installation and configuration file are operating adequately. However, I would REALLY like to see a 3D view of my range. 2D is fine as far as it goes for the basic knowledge about horizontal coverage, but I think that better understanding of the vertical arena could be equally important, as thermaling in close quarters often puts other gliders in a blind spot for both parties. If Flarm can help recognize these encounters, we need to be sure that our installation can at least pick up a Flarm signal from above and behind or below and in front. Both are scenarios that can rapidly increase the chances of more than scuffed paint.
Old June 8th 17, 04:08 PM posted to rec.aviation.soaring
Dan Marotta
Well put, Mark.
I recall a flight with a Discus 2 below me. Neither of us could see the
other on Flarm (we had visual contact) but, when I rolled into a steep
bank allowing the antennae to "see" each other, we got electronic hits.
The obvious solution would be to place an antenna on the bottom of the
ship but since there's only one transmit antenna (Flarm A), it wouldn't
make much of an improvement.
Dan, 5J
Old June 8th 17, 04:42 PM posted to rec.aviation.soaring
Dan Marotta
I'll try to remember to get a picture but here's a description:
The Flarm portable is mounted to the top center of the glare shield on
the Stemme. The B antenna is mounted through a grommet directly in
front of me (left side) and about 6 inches forward of the aft edge of
the glare shield. The A antenna is mounted in the same location on the
right side of the glare shield (right side) and the ADS-B antenna is
mounted about 6 inches in front of the A antenna. The GPS antenna is
mounted on top of the glare shield near the forward center. I cut the
coax cables to length and ran them along the under side of the glare
shield cover where they exit their own grommets a couple of inches away
from where the antennae are mounted allowing for a perpendicular run of
coax from the antenna before turning down under the glare shield.
Chip Bearden
Dan, 5J
Old June 8th 17, 10:49 PM posted to rec.aviation.soaring
George Haeh
Both A & B antennae will be blocked by the engine and one or two bodies.
I'd look into placing the B antenna behind the gear in the tailcone.
On two Scout towplanes, I taped the dipole to a structural cross piece with
a
bit of balsa in between and connected to the A port. The B port got the
straight up antenna.
Old June 9th 17, 03:58 AM posted to rec.aviation.soaring
Dan Marotta
Here are those pictures you asked for:
https://www.dropbox.com/s/nd4z1itc0i...41.15.jpg?dl=0
https://www.dropbox.com/s/fxt1nog20c...23.34.jpg?dl=0
https://www.dropbox.com/s/banwv1ljv1...23.23.jpg?dl=0
https://www.dropbox.com/s/2bqq8ez1ag...22.30.jpg?dl=0
Hope that helps. I know it would help with my reception to place the B
antenna on the bottom of the aircraft, but that would be a pain in the
behind - hardware, cabling, convincing the IA to sign off the
installation, etc.
Dan
the right side of the glare shield (right side) and the ADS-B antenna
is mounted about 6 inches in front of the A antenna. The GPS antenna
is mounted on top of the glare shield near the forward center. I cut
the coax cables to length and ran them along the under side of the
glare shield cover where they exit their own grommets a couple of
inches away from where the antennae are mounted allowing for a
perpendicular run of coax from the antenna before turning down under
the glare shield.
itself.
Chip Bearden
Dan, 5J
Old June 9th 17, 06:40 AM posted to rec.aviation.soaring
The problem is that the B antenna is receive only. So if the other guy is in you blind spot, he won't see you even if you can see him. A RF opaque glider needs at least two transmit antennas to get a full situational picture.
And as Mark points out, the range tool is a 2D projection of 3D data. So the good range shown could be based on a cone pointing up or down. It's possible your range is near zero on or near the horizon.
Maybe the range tool should provide several charts for different azimuths. But ti would still not be quite right because some hits would be while the glider is banked. So now the range tool should analyze the track and estimate bank angle.
Gets complicated pretty fast :-)
5Z
a
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 05:31 AM
FLARM Range [email protected] Soaring 11 June 17th 15 12:44 AM
Flarm range Ramy[_2_] Soaring 7 May 8th 15 12:02 AM
PowerFlarm Range Analysis for "WX" - 15M Nats Yreka 2014 WaltWX[_2_] Soaring 13 March 27th 15 11:34 PM
PowerFlarm Range Analysis Richard[_9_] Soaring 0 March 25th 13 05:43 PM
