Flarm firware update tries produce "Synchronization Failed" message.
Old June 6th 17, 05:04 AM posted to rec.aviation.soaring
Jim[_33_]
Default Flarm firware update tries produce "Synchronization Failed" message.
I have been trying to apply the latest Flarm firmware update to the Flarm in our ASG-32Mi with an LX9000 installed.
I have tried many times and every time the result is a "Synchronization Failed" message. I have looked for an explanation of this error message in the Flarm manuals, on the Flarm.com website, on the web in general, on rec.aviation.soaring and have found nothing.
Does anyone know what is going on with my update attempts?
Old June 6th 17, 05:28 AM posted to rec.aviation.soaring
[email protected][_2_]
Default Flarm firware update tries produce "Synchronization Failed"message.
You can't update the flarm in a 9000 unless you've installed all updates
for the 9000 first. Done? Check the LXnav website.
I speak from experience.
GC
Old June 6th 17, 02:47 PM posted to rec.aviation.soaring
Do all the previous updates need to be put into the portable FLARM too? My unit shows 6.09 on startup, but only shows transponders, no FLARM targets. I may have taken it back to zero updates while trying to get 6.09 in. I hate this digital crap!
JJ
Old June 6th 17, 03:07 PM posted to rec.aviation.soaring
Dan Daly[_2_]
JJ
If 6.09 shows, you should be good. Did you re-install your flarmcfg.txt file after the firmware update? Something may have gone astray when the old one was replaced.
The other possibility, since pcas/transponders show and flarm doesn't, is that your flarm antenna may have a problem. I'd unscrew and screw it back in and see if that works.
Cheers
Dan
Another FLARM update with no notice Dan Daly[_2_] Soaring 1 September 19th 16 05:30 PM
Oudie Update Failed: Says not valid Win32 Application Sean F (F2) Soaring 8 October 1st 13 08:20 PM
Flarm with Firmware 1.20 update Robert Fidler[_3_] Soaring 49 January 31st 12 04:40 PM
FLARM UPDATE? Stephen Michalik Soaring 6 March 20th 11 05:24 PM
CAI 302 security failed message Joseph L. Hyde Soaring 9 September 17th 04 07:47 AM
