Static ports and Irving TE probes
Old June 30th 17, 06:35 PM posted to rec.aviation.soaring
Jim[_33_]
Default Static ports and Irving TE probes
I am trying to understand how TE probes are connected. I've searched the literature but apparently have not found the description I'm looking for.
Are the fuselage static ports connected (used in any way ) in an Irving TE probe is installed?
Old June 30th 17, 08:07 PM posted to rec.aviation.soaring
Dan Marotta
A TE probe provides a single pneumatic signal and is connected directly
to the TE port on your variometer or computer.
Fuselage statics and pitot input may also be connected to their
appropriate ports for electronic compensation in a flight computer, if used.
Dan, 5J
Old June 30th 17, 08:47 PM posted to rec.aviation.soaring
Garrett McEwen
My question is more general. Can anyone provide an overview of all the TE, triple probe, etc. options and maybe their history?
There are so many shapes and sizes and I've always wondered how and why that came to be and what advantages and disadvantages they each carry.
Old July 1st 17, 12:52 AM posted to rec.aviation.soaring
Bob Kuykendall
The classic TE probe carries only one pneumatic signal from an orifice on the aft-facing surface of a cylinder. I think that the signal is essentially the inverse of pitot pressure. When plumbed to a vario instead of a static port, it cancels out climb or descent effects due to changes in the glider's inertial state caused by pitching up or down. The effect is to make the vario display the net gain or loss of total (potential plus kinetic) energy state.
More modern probes may also feature orifices positioned to measure static air pressure and even pitot pressure. Positioning these orifices on the probe in clean air out away from the glider makes it possible to get more accurate measurements of these pressures. The downside is that such probes can be difficult to retrofit to older sailplanes. They are also a bit fussy about connecting or disconnecting the probe itself during assembly and disassembly. The O-ring seals have finite lifespan, and when they start to leak the different pneumatic signals corrupt each other, often with confusing or misleading symptoms.
As for the TE probe orifice, there are a variety of claimed and illusory advantages for different shapes and patterns--holes, pairs of holes, slots and pairs of slots, ad infinitum. Oran Nicks, working with Dick Johnson, demonstrated that a single hole of diameter 1/3D works about as well as anything. When it comes down to it, all TE orifices suck.
--Bob K.
Old July 1st 17, 05:18 PM posted to rec.aviation.soaring
Dan Marotta
--Bob K.
:-D
Dan, 5J
Static Ports question C2[_2_] Soaring 17 November 19th 13 08:39 AM
Static ports Grider Pirate Soaring 5 August 20th 10 05:07 PM
DG-600 AOA static ports Marc Ramsey Soaring 0 February 14th 07 11:37 PM
Frank Irving Martin Judkins Soaring 0 August 25th 05 02:47 PM
Four Static Ports! Which to Use? John DeRosa Sky Soaring Chicago IL Soaring 3 May 18th 04 05:55 PM
