Welsh airlift ends in crash (1949)
Old August 22nd 17, 05:46 PM posted to alt.binaries.pictures.aviation
Byker
Default Welsh airlift ends in crash (1949)
Westland-Sikorsky Dragonfly
Crash alone: https://www.youtube.com/watch?v=FPF9OP7Jync&t=86s
British Pathé newsreel: https://www.youtube.com/watch?v=t-FskGz2XyI
No apparent injuries.
I've seen lots of B&W crash footage, but this is a new one on me...
Old August 22nd 17, 06:04 PM posted to alt.binaries.pictures.aviation
john szalay
"Byker" wrote in news:C6adnZkiOMRvwgHEnZ2dnUU7-
Crash alone:
Sling loads are tricky any way, but in windy locations,such as valleys and
mountains sides, even more so.
Old August 22nd 17, 09:24 PM posted to alt.binaries.pictures.aviation
Miloch
In article , Byker says...
Flying rule of thumb:
"Anytime you can walk away from a landing...it was a good landing".
Old August 24th 17, 11:23 PM posted to alt.binaries.pictures.aviation
Byker
"Miloch" wrote in message news
After seeing so many crashes attributable to tail rotor failure, I wonder
why there aren't more twin-rotor manufacturers, like Kaman and Kamov?
Old August 25th 17, 12:02 AM posted to alt.binaries.pictures.aviation
Miloch
Went thru flight school in the 60s and was assigned to fly TH-55s as my trainer.
The first models had a tail rotor that spun at close to the speed of sound...it
was OK unless it rained. The high speed of the tail rotors hitting the rain
drops could cause them to shatter!
Old August 25th 17, 06:17 AM posted to alt.binaries.pictures.aviation
Bob (not my real pseudonym)[_2_]
Also wondering how well the NOTAR idea is working out? Don't see that
many, percentage-wise.
Old August 25th 17, 03:19 PM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
On Aug 24, 2017, Byker wrote
(in ):
The Kaman K-Max is impressive.
I first saw one in action last year, as one of the fleet of aircraft fighting
our massive local, 46,344 acre “Chimney†fire which destroyed 49 homes
and 21 other structures.
Our local airport at Paso Robles with its CalFire Air Attack base seemed to
have tankers landing to reload every few minutes. From take off they would be
in orbit over the drop zones out at Lake Nacimiento with the
controller/observers in OV-10’s. The helicopters would take water from the
lake with buckets, or pump filled tanks. That fire burned from August 13 to
September 6.
Regards,
Savageduck
Old August 25th 17, 06:32 PM posted to alt.binaries.pictures.aviation
john szalay
"Bob (not my real pseudonym)" wrote in
wonder why there aren't more twin-rotor manufacturers, like Kaman and
Kamov?
local PD flies one, sounds a little different, a little quieter. but not
silent.
Old August 25th 17, 07:03 PM posted to alt.binaries.pictures.aviation
Byker
Interesting observation:
"The US uses tandem rotor helicopters because they are easier to make and
maintain; its biggest requirement is a sophisticated transmission design
that needs to be placed between the two rotors to ensure they rotate evenly
and the blades never intersect (even when one engine fails).
"Co-axial helicopters are much harder to make and the entire engine and
rotor design is extremely mechanically complex.
"Just building a regular engine axel is difficult, and the finished axel is
virtually impossible to inspect for internal voids or cracks. Any internal
defects will result in a catastrophic failure when the engines spins up to
speed the first time. Even now, many turbine engine manufacturers do their
first engine start in something that looks like a giant steel bunker because
there's just no way to be sure the axel at the heart of that engine won't
explode; literally explode. You want to make axels that go inside axels and
spin in opposite directions? That's a lot harder...
"Personally, I have no idea why Russia chose such a complex and difficult to
manufacture helicopter design. Igor Markov may be able to explain the logic
behind that decision. He is very knowledgeable about Russia and has written
some of my favorite Quora answers about that part of the world. I'm sure
there is a reason; I just don't know it.
"Personally, it reminds me of the Russian booster rocket designs from the
race to the moon. The US built the Saturn V stage 1 rocket with five engines
that had to fire simultaneously and equally. The Russians designed the N1
lunar rocket that contained 30 (smaller) engines in stage 1 that had to fire
simultaneously and equally. The Americans got the the moon first (in part)
because it's much easier to control and balance 5 engines simultaneously
than it is to control and balance 30 simultaneously."
https://www.quora.com/Why-hasnt-Russ...tor-helicopter
Old August 25th 17, 09:04 PM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
and maintain; its biggest requirement is a sophisticated transmission
design that needs to be placed between the two rotors to ensure they
rotate evenly and the blades never intersect (even when one engine
fails).
axel is virtually impossible to inspect for internal voids or cracks.
Any internal defects will result in a catastrophic failure when the
engines spins up to speed the first time. Even now, many turbine engine
manufacturers do their first engine start in something that looks like
a giant steel bunker because there's just no way to be sure the axel at
the heart of that engine won't explode; literally explode. You want to
make axels that go inside axels and spin in opposite directions? That's
a lot harder...
difficult to manufacture helicopter design. Igor Markov may be able to
explain the logic behind that decision. He is very knowledgeable about
Russia and has written some of my favorite Quora answers about that
part of the world. I'm sure there is a reason; I just don't know it.
the race to the moon. The US built the Saturn V stage 1 rocket with
five engines that had to fire simultaneously and equally. The Russians
designed the N1 lunar rocket that contained 30 (smaller) engines in
stage 1 that had to fire simultaneously and equally. The Americans got
the the moon first (in part) because it's much easier to control and
balance 5 engines simultaneously than it is to control and balance 30
simultaneously."
I
don't believe the K-Max K-1200 is dependant on a co-axial system, but
uses an inter-meshing "eggbeater" dual rotor.
http://www.kaman.com/aerosystems/solutions/air-vehicles-mro/k-max
http://fireaviation.com/tag/k-max/
http://www.flyingmag.com/aircraft/helicopters/kaman-restarting-k-max-k-1200-production
https://youtu.be/4dJyUFgY0a8
Regards,
Savageduck
Berlin Airlift, IFR Paul[_4_] Instrument Flight Rules 41 June 3rd 14 12:02 AM
flying brothers [12 of 26] "Arthur Welsh's Wright Model CM-1 Flyer after crash on June 11, 1912.jpg" yEnc (2/2) no name Aviation Photos 0 August 22nd 09 06:37 AM
flying brothers [12 of 26] "Arthur Welsh's Wright Model CM-1 Flyer after crash on June 11, 1912.jpg" yEnc (1/2) no name Aviation Photos 0 August 22nd 09 06:37 AM
Update on VacationRentalsforFamilies Airlift Peter R. Owning 14 September 9th 05 12:57 AM
Update on VacationRentalsforFamilies Airlift Peter R. Piloting 10 September 9th 05 12:57 AM
