Unable to Update PowerFLARM Portable Firmware
Old September 2nd 17, 07:57 PM posted to rec.aviation.soaring
Dan Marotta
Default Unable to Update PowerFLARM Portable Firmware
Hi All,
I have downloaded the most recent PowerFLARM firmware, filename:
pf_00cecdb_6_40_exp_1_Feb_2019.fw.Â* Per the instructions for micro SD
cards published on the FLARM website, I've attempted to update the
firmware three times as follows:
Copy the firmware file to the root level of the SD card
Insert the SD card
Apply power
My PF portable comes up quickly showing fw version 6.08.Â* There's no
30-second update time as mentioned in the instructions.Â* The
instructions say to interrupt power for at least 5 seconds after
inserting the card.Â* It seems to me that inserting the card in an
unpowered unit serves the same purpose.Â* Could that be why my unit won't
update?
Dan, 5J
Old September 2nd 17, 08:49 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Sat, 02 Sep 2017 11:57:55 -0600, Dan Marotta wrote:
Copy the firmware file to the root level of the SD card Insert the SD
card Apply power
update?
I did exactly that, only with the Classic FLARM 6.40 program and an LX
RedBox FLARM: because I always insert and remove the SD card with the
FLARM powered off. Mine did the install as soon as it was powered on: I
could see the power LED flashing red during the install and, in due
course that turned green and the unit lit the GPS LED red as it started
looking for a GPS signal.
Normally, with the SD slot empty, my power LED shows steady red while it
boots. Then the power LED turns green and the GPS LED lights up red to
show its looking for a GPS signal.
Is it possible that your PF portable didn't notice the SD card? It might
be worth cleaning its contacts before trying again.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 2nd 17, 09:20 PM posted to rec.aviation.soaring
Dave Nadler
On Saturday, September 2, 2017 at 1:58:00 PM UTC-4, Dan Marotta wrote:
Hi All,
Insert the SD card
Apply power
update?
Dan, 5J
Reformat the SD card on Windows, copy just the FW onto the freshly
formatted card, and give it another try...
Old September 2nd 17, 11:54 PM posted to rec.aviation.soaring
Dan Marotta
On my initial attempt I had a profile file installed on the SD card and
there was a message on the splash screen stating that the profile was
being updated, then no update to the firmware.Â* I removed the profile
file and tried again.Â* This time, the PF portable simply booted up.Â*
I'll try cleaning the contacts and, as Dave suggested, I'll also format
the SD card to FAT32 and install only the .fw file.Â* I should have
results tomorrow.
Dan
card Apply power
update?
Dan, 5J
Make sure the SD card is 32gb or smaller and is formatted FAT32. exFAT or NTFS will not be recognized by the PowerFlarm.
Robert
On Saturday, September 2, 2017 at 12:58:00 PM UTC-5, Dan Marotta wrote:
Hi All,
Insert the SD card
Apply power
update?
Dan, 5J
Old September 3rd 17, 12:16 AM posted to rec.aviation.soaring
"To err is human, to totally screw up requires a computer".
Sigh, instamatics and a Replogle was sometimes easier......
Old September 3rd 17, 12:29 AM posted to rec.aviation.soaring
Dan Marotta
Finished all my Diamonds that way.Â* I think it *was* easier...
Dan, 5J
Old September 3rd 17, 03:14 PM posted to rec.aviation.soaring
Tango Eight
On Saturday, September 2, 2017 at 6:16:50 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
Charlie: yer outta date. On modern equipment, flight declaration, recording, subsequent evaluation is completely painless.
Flarm -should be- equally painless, in all respects. It isn't.
-Evan Ludeman / T8
Old September 3rd 17, 03:22 PM posted to rec.aviation.soaring
Did you try going under "menu-info-update" to force it to look for the update?
Old September 3rd 17, 07:09 PM posted to rec.aviation.soaring
Dan Marotta
I didn't see that option.Â* I'll look if the freshly formatted SD card
doesn't work.
Dan, 5J
New PowerFLARM firmware 6.40 Dan Daly[_2_] Soaring 15 September 5th 17 07:23 AM
PowerFlarm Firmware Karl Kunz[_2_] Soaring 9 March 15th 17 03:44 PM
PowerFLARM Portable Firmware Update: 6.02 Paul Remde Soaring 15 April 10th 15 04:13 PM
Portable PowerFlarm hardware update kd6veb Soaring 8 March 22nd 13 11:44 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 02:50 AM
