Repairing gel coat chips
Old April 16th 04, 04:12 PM
Gary Evans
Default Repairing gel coat chips
I there a way to thicken gel coat other than letting
some of the solvent evaporate? Even the thinnest commerical
gel coat is made for spraying which makes it too runny
for filling small cometic chips. The only gel coat
paste fillers I have found are an off white in color.
Old April 16th 04, 05:00 PM
JJ Sinclair
You can use white micro-balloons to thicken gelcoat. It won't polish out very
well, but it's white.
JJ Sinclair
Old April 16th 04, 11:13 PM
mike
Gary Evans wrote in message ...
You can take a small amount polester coating like Prestec (basically
gel coat)and over catlyze it at around 4%. Stir and watch it as it
thickens which may take around ten minutes depending on temperature.
When it gets to the viscosity you like, apply it to the roughed up and
well cleaned area. Prestec is about the whitest thing known to man so
if your gell coat has faded a bit you can add a minute amount of
yellow polyester dye. __Mike
Old April 17th 04, 05:35 AM
David Kinsell
"Gary Evans" wrote in message ...
Plastics shops sell colloidal silica filler, which you can mix in
the gel coat before adding the catalyst. It's white, and a whole
lot safer than microballoons, which can waft into your lungs
and do real nasty things.
Old April 24th 04, 06:23 PM
David Kinsell
"David Kinsell" wrote in message news:rC1gc.156346$K91.409573@attbi_s02...
If you get the West System filler, the 406 is pure white, but the 407
is a purple color.
Old April 24th 04, 06:47 PM
Gary Evans
Thanks David. I found the specs for 406 and see that
it is a colloidal silica thats to be added to regular
gel coat. They claim that it is off-white in color.
When mixed with gel coat does it color match an unweathered
glider finish and will it accept a polish?
Thanks!
At 16:36 24 April 2004, David Kinsell wrote:
'David Kinsell' wrote in message news:rC1gc.156346$K91.409573@att
bi_s02...
'Gary Evans' wrote in message .
uni-berlin.de...
commerical
runny
you can mix in
and a whole
your lungs
white, but the 407
is a purple color.
Old April 27th 04, 04:23 AM
David Kinsell
Thanks!
The color is a very good white, I don't think most people would call it
off-white. I've never noticed any color change as a result of adding it.
As far as sanding ability goes, the label rates it as one of the highest-strength
fillers, but tougher to sand. The 403 is supposed to be the next grade
easier to sand. Then there's three low-density fillers that are easiest to
sand, but they're all colored. Chip-filling is easy to sand, so I'd expect you'd
be happy with the results from either the 403 or 406.
-Dave
Repairing Plastic Interior Parts of 40-year-old Aircraft jls Home Built 6 December 7th 04 11:04 PM
Repairing fiberglass wheel pants Jay Honeck Owning 18 September 25th 04 04:55 AM
One coat paint for aluminum? [email protected] Home Built 10 September 17th 04 08:01 AM
Water-borne barrier coat larsen-tools Home Built 0 February 3rd 04 09:42 PM
Refinishing: Who has tried a shortcut? Ian Forbes Soaring 60 December 26th 03 10:30 AM
