Discus b versus Discus CS
Old November 1st 17, 02:48 AM posted to rec.aviation.soaring
Default Discus b versus Discus CS
I've read that the Discus b and Discus CS are "identical" except that the CS is manufactured under license in Czech Republic. Both are, of course, available in the used-glider-market. Are there any differences in reliability, manufacturing qualty, etc that would favor one over the other?
Tom
Old November 1st 17, 09:54 AM posted to rec.aviation.soaring
As well as building the Discus the Czech SH factory builds other gliders for them - all Duos were being built there and then fitted out in Germany when we got one in 2001. Earlier I had a half share in a German built Discus BT that, after being broken by a partner, ended up with a new Czech wing and the older German one. The only difference was a slight difference in the spar stub GRP colour.
There was a major issue around 15 years ago when some Czech built wing spars were found to have inadequately bonded top caps and there was a big program of internal inspection and repairs if indicated. Assuming that any Discus CS from that era had the inspection done and recorded properly then I wouldn't have any other concern about relative original build quality of B and CS models.
The CS was offered with some standard features that were optional on Bs - the main one being a tilting panel which is a very desirable.
Old November 1st 17, 05:06 PM posted to rec.aviation.soaring
Tom
Thanks jpg, very helpful.
Tom
Old November 1st 17, 06:03 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
For the last few years of production most of (all?) the Discus b gliders
were built in Czech republic anyway (S/N 551+).
Our Discus bT has a German Fus and Czech wings.
The Gelcoat on the wings is in far better condition than the fuselage
Regards
the=
course,
reliabil=
=20
Tom
Tom
Old November 2nd 17, 08:14 PM posted to rec.aviation.soaring
Tom
I'm a little confused here - is the CS the same design as the earlier Discus, or later Discus 2?
Old November 2nd 17, 09:05 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Early Discus, Jeff. The CS is different manufacture of the Discus B.
Old November 2nd 17, 09:12 PM posted to rec.aviation.soaring
Tom
No meaningful difference except CS likely to be newer. But the best example you can find of either one.
UH
Discus 2b versus LS-6c [email protected] Soaring 14 September 20th 17 02:31 PM
304 versus Discus B Del Jensen Soaring 7 March 2nd 17 02:19 AM
Discus verus Discus 2, LS8, ASW 28 Roger Soaring 45 October 31st 06 04:43 PM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 02:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 09:42 AM
