Grob mechanic in the Midwest?
Old November 8th 17, 03:02 AM posted to rec.aviation.soaring
Tango Papa IN
Default Grob mechanic in the Midwest?
There was a complicated AD on the Grob 102 a while back, the wing spar spigot assemblies work.
Recently I ran a cross more than one gliders that just hibernating and waiting to be comply with this AD. Grob used to have a service shop in Ohio. Is anyone from Grob left behind that did this AD before? I am not able to drive to NM and back. Is anyone else successfully did this AD before around Indiana-Ohio-Illinois-Michigan? I appreciate your help!
Thanks
Old November 8th 17, 12:25 PM posted to rec.aviation.soaring
Thanks
There is guy that has done these in Philly, PA... Contact Jack G thru PGC Soaring Club.
Old November 8th 17, 01:22 PM posted to rec.aviation.soaring
Thanks
John Murray (Eastern Sailplane) in Waynesville OH, still does sailplane repair work.
Old November 8th 17, 03:44 PM posted to rec.aviation.soaring
Thanks
Gehrlein Products in Waterford, PA is a Sailplane Repair Station. They have been working on composite gliders since the first Libelles were imported and supported by them.
Old November 10th 17, 07:58 PM posted to rec.aviation.soaring
Recently I ran a cross more than one gliders that just hibernating and waiting to be comply with this AD. Grob used to have a service shop in Ohio.. Is anyone from Grob left behind that did this AD before? I am not able to drive to NM and back. Is anyone else successfully did this AD before around Indiana-Ohio-Illinois-Michigan? I appreciate your help!
Thanks
The Gehrlein's have worked on my glider and the my club's glider. They do excellent work.
Old November 10th 17, 04:38 AM posted to rec.aviation.soaring
Thanks
I got mine done at XU aviation in London Ontario. They had done several before mine.
Toad Smith
3S
If you're a mechanic you can relate to this [email protected] Piloting 19 October 20th 07 01:29 PM
If you're a mechanic you can relate to this [email protected] Owning 18 October 20th 07 01:29 PM
If you're a mechanic you can relate to this [email protected] Home Built 18 October 20th 07 01:29 PM
A-65 mechanic question Michael Horowitz Home Built 24 May 30th 05 11:08 PM
Mechanic in MN [email protected] Piloting 2 March 24th 05 03:09 AM
