Jantar SZD 48 "Jantar Std 2" - wing profile templates
Old November 22nd 17, 11:15 PM posted to rec.aviation.soaring
Phil Stade[_2_]
Default Jantar SZD 48 "Jantar Std 2" - wing profile templates
I am looking for wing profile data for the Jantar SZD 48 Std 2. Anyone have that information?
Thanks
Phil
Old November 24th 17, 06:33 AM posted to rec.aviation.soaring
Phil Stade[_2_]
Thanks
Phil
Our Jantar is Serial W-856 built in 1984. The Flight Manual from Jantar Serial B-1049 says that the wing profile is NN8. Some sources indicate a Wortmann profile. Is there another way of determining the profile used on W-856?
Thanks
Phil
Old November 28th 17, 06:35 AM posted to rec.aviation.soaring
Bob Kuykendall
I've collected profiles from half a dozen airplanes and gliders, and in general there seems to be only a passing resemblance between what is manufactured and its published coordinate sets. Of course, it is much better these days with the increasing use of very stable CNC-cut molds. But even as recently as the mid 1990s you could find new gliders with very marked differences not only between published and actual coordinates, but even between right and left wings.
If you really want to know what's there, your best bet is to extract your own coordinate set. One such method is described in my 2006 Update called Steal This Airfoil:
http://www.hpaircraft.net/hp-24/upda...ecember_06.htm
Thanks, Bob K.
Old November 28th 17, 07:31 PM posted to rec.aviation.soaring
Bob,
Define "straight and square". Most wings have leading edges that are swept back and/or trailing edges that are swept forward. In fact, unless it's a constant chord wing (a la the old HP-10), the leading and trailing edges aren't parallel. And neither one may be perpendicular to axis of the fuselage (i.e., direction of flight). So how to align the foam core board on which you trace the airfoil?
I guess if all you're doing is creating templates to use during refinishing, it doesn't matter how you align it so long as you can duplicate the same alignment after the old gel coat is stripped off and new gel coat is applied. In that case, aligning the "chord" perpendicular to the leading edge probably works fine. But is that true if you're really trying to pull coordinates?
Chip Bearden
Old November 28th 17, 07:49 PM posted to rec.aviation.soaring
Bob Kuykendall
On Tuesday, November 28, 2017 at 10:31:04 AM UTC-8, wrote:
Bob,
Parallel with the fuselage longitudinal axis, orthogonal to the plane containing the leading and trailing edges. In the absence of sweep reference, splitting the difference between the leading and trailing edges will get you plenty close enough. Which is to say, closer than the difference between the right and left wings on your glider.
--Bob K.
Old November 28th 17, 08:33 PM posted to rec.aviation.soaring
Mike C
Bob,
--Bob K.
A few years ago Robert Mudd and I had CNC templates made for a PIK 20B according to the airfoils used and blended from root to tip. I do not think there was one station that had the correct airfoil shape and one wing did not agree with the other as far as deviations that were fairly large.
Old November 29th 17, 12:54 AM posted to rec.aviation.soaring
Dan Marotta
Mike,
Were the flying qualities and performance noticeably improved after
profiling the wings?
Bob,
--Bob K.
Dan, 5J
Old December 7th 17, 01:41 AM posted to rec.aviation.soaring
Mike C
On Tuesday, November 28, 2017 at 4:54:15 PM UTC-7, Dan Marotta wrote:
Mike,
Bob,
--Bob K.
Dan, 5J
No idea it was a project that remains unfinished in it's trailer.
Old June 9th 20, 02:04 PM posted to rec.aviation.soaring
Piotr Szafranski
Thanks
Phil
It is called NN-8. Cl(alpha) can be found in
INFLUENCE OF MINIFLAPS ON SAILPLANE FLIGHT CHARACTERISTICS
Peep LAUK1, Karl-Eerik UNT
AVIATION
ISSN 1648-7788 / eISSN 1822-41802015 Volume 19(3): doi:10.3846/16487788.2015.1104793
pages 105–111 Fig.12.
https://www.researchgate.net/publica...cteristics.pdf
LS-3 Wing Profile Templates Dan Marotta Soaring 2 November 11th 11 04:50 PM
Wanted SZD Jantar STD 2 wing tip [email protected] Soaring 1 May 27th 06 11:48 PM
LAK-12 or a Jantar, and which model Jantar? rich Soaring 11 July 18th 05 11:54 PM
ASW27 wing profile templates basils27 Soaring 0 June 29th 05 12:46 PM
Jantar VNE Craig Storey Soaring 2 December 9th 03 01:33 AM
