TE probe for SGS2-33
Old May 20th 04, 03:23 PM
Rod Pool
Default TE probe for SGS2-33
Interested in info on TE probe locations, type of probes etc for
install on a SGS 2-33. Probe location seems problematic on a 2-33.
Would a diaphragm be a better choice?
TIA
Old May 20th 04, 06:08 PM
Bob Kuykendall
probes etc for
install on a SGS 2-33...
I'd recommend a homemade Nicks tube mounted with the
pitot/static cluster on the top of the nose. It would
be inexpensive, effective, and commensurate with the
prevailing aesthetic of the aircraft.
The angle of the factory pitot/static cluster means
that you wouldn't need the 20-degree bend normally
specified for the Nicks probe.
Here are links to two related articles:
http://www.soaridaho.com/Schreder/Co...ROBE_ANTENNA.h
tml
http://www.ssa.org/Johnson/89-1998-04.pdf
You should be able to put the whole thing together
for about three dollars in parts.
Bob K.
http://www.hpaircraft.com
Follow-up probe ordered into June 'friendly-fire' hit Otis Willie Military Aviation 0 March 3rd 04 03:46 AM
Whats that probe which sticks out of the aircraft nose? Gangatharan Products 1 February 12th 04 03:06 PM
Cleaning a 3-way TE probe Jack Glendening Soaring 37 November 5th 03 06:45 PM
Cleaning TE probe - is this a good idea ? JJ Sinclair Soaring 1 October 7th 03 02:30 PM
Broken line to Oil Temperature Probe, Repairable? rkane33 Owning 2 July 25th 03 03:19 AM
