Real Holder of the Glider Altitude Record, NOT RUTAN ON 21 JUNE
Old June 4th 04, 06:17 AM
Janus2k
Default Real Holder of the Glider Altitude Record, NOT RUTAN ON 21 JUNE
From Current issue of EAA Sport Aviation, June 04.
Letter to the editor:
"I've enjoyed all the articles you've done on Bruce Bohannon's record
attempts. However, every time I read one I always wondering the same thing at
the end: When is he going to pass the current glider altitude record (49,009
feet)?
He only has about 2,000 more feet to go!"
Written by Bob Mowry, whom I suspect could be lurking here! Congrats!!!!!!!
Made my day.
What Rutan doing is great, however it's not a glider in my humble opinion.
Would we consider Bob Harris the altitude record holder if he towed to 49,009
and then glided back to Cal City?
Just thought I stir it up a little!!!!!!!!
Mark Mahan
2K
Old June 4th 04, 07:01 AM
Arbr64
49,009
Of course not.
The SS1 is a Rocket Plane, it qualifies under the "Aircraft launched by a
carrier Airplane" category, exactly like the X-15 decades before, which
never claimed a "Soaring Performance" Record.
FAI specifies a Motor-glider as being a "A fixed wing aerodyne equipped with
means of propulsion (MoP), capable of sustained soaring flight without
thrust from the means of propulsion."
The X-15's and SS1's performances are 100% dependent on their engines and
ballistic trajectories (coasting) after engine shutdown, they can't sustain
soaring flight by utilizing any atmosphere generated form of lift to improve
performance beyond their limited glide ratios, so their flights can't be
technically considered "Soaring Performances".
Old June 4th 04, 01:02 PM
Bob
Wouldn't that make the STS (a self launch glider) the holder of the altitude record?
Bob
Old June 4th 04, 02:20 PM
plasticguy
"Bob" wrote in message
om...
altitude record?
Bob
No, but it might mean that a P-38 Lightning is a motorglider since it has
been wave soared with both engines caged
for a couple hours.
Scott.
Old June 4th 04, 02:32 PM
John Jones
At 12:36 04 June 2004, Plasticguy wrote:
'Bob' wrote in message
. com...
the holder of the
altitude record?
Bob
since it has
for a couple hours.
Scott.
The Burt Rutan SpaceShip One looks very light weight,
so I would assume it has some modest glide performance...albeit
likely at a higher speed than what we are used to.
Bet if it ran into mountain wave on the way back down
from space, it could climb in the wave. That would
meet the definition of glider then.
Old June 4th 04, 10:54 PM
Arbr64
Correct, that P-38 was capable, under strong wave conditions, of a "Soaring
Performance".
It could have tried for an altitude record if, after engine shutdown, it
gained at least 5000m in wave AND exceeded the previous altitude record.
"plasticguy" wrote in message
om...
altitude record?
Bob
for a couple hours.
Scott.
Old June 4th 04, 11:10 PM
Arbr64
The SS1s drawback for a soaring performance is high Wing Loading and very
low aspec-ratio wings.
This means high stall speed and high sink rates, both non-conducive to
significant soaring performances.
The average sink rate according to their public data is 2500ft/min, and
stall speed with one person on board and no fuel was 70kts.
Old June 5th 04, 02:29 AM
Mark James Boyd
I vaguely recollect that altitude records require some fairly
healthy altitude gain to be valid in soaring. I believe this
applies to absolute altitude as well. IIRC one must
have a gain of diamond altitude to claim a absolute altitude
world record. I'm not certain about state records, but
may have read somewhere that silver gain is
required for state/national absolute altitude records...
AHA...Virginia requires:
3.0 Minimum Performance : Absolute Altitude records must include
an altitude gain of at least 3,281 feet.
Somebody else can look up the World Record requirement
http://www.brss.net/Rules.htm
Mark Boyd
Avenal, California, USA
Old June 5th 04, 06:54 AM
Arbr64
Already did, read my previous posting. It's 5000m, around 16000ft.
Old June 5th 04, 06:55 AM
Tim Ward
"Arbr64" wrote in message
. com...
I'm betting Spaceship1 will climb at least 3281 feet after MECO.
Tim Ward
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 11:41 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 05:26 PM
Restricting Glider Ops at Public Arpt. rjciii Soaring 36 August 25th 03 05:50 PM
