More 3's?
Old January 17th 18, 10:13 PM posted to rec.aviation.soaring
Default More 3's?
With tried and true Ventus 3 and JS3, wonder how long before the ASG-33?
Old January 17th 18, 10:19 PM posted to rec.aviation.soaring
Default More 3's?
And maybe soon the 2-33B
Old January 18th 18, 02:42 AM posted to rec.aviation.soaring
Andrzej Kobus
Default More 3's?
Why would you want ASG-33 if ASG-29 can outfly V3 in strong conditions? It seems there was a need to put a limit on wing loading for Grand Prix to make the V3 competitive.
Old January 18th 18, 04:14 AM posted to rec.aviation.soaring
Default More 3's?
You will need an ASG-33 not to outfly a V3 - but the JS-3. The V3 and JS-1c (18m) match each other with the same wingloading as seen in Chile yesterday - and the JS-3 is a decade newer than the JS-1.....
Maybe I am just biased being a South African - but I am thinking the Germans have some catching up to do in the next few years. The JS-3 is going to be unbeatable in 15m and 18m Classes - and the JS-1c will still be very competitive in the Open Class in any competition. This advantage will be even greater where wingloading is a factor (strong days) and especially where it's weight that's limited, and not wingloading (like the Sailplane GrandPrix)..
Old January 18th 18, 09:25 AM posted to rec.aviation.soaring
krasw
Default More 3's?
torstai 18. tammikuuta 2018 5.14.33 UTC+2 kirjoitti:
Sebastian Kawa commented that V3 was much better in final glide, and it was quite obvious just by watcing races. No doubt engineers at Schleicher are at drawing board as we speak. Currently only interesting thing is how V3 and JS3 compares, JS1 and '29 belong to previous generation.
Old January 18th 18, 10:17 AM posted to rec.aviation.soaring
Ian[_2_]
Default More 3's?
I am also a biased South African :-). With 3 declared 1250km FAI
triangles logged on OLC in 2018, the JS3 is clearly very competitive.
But the most remarkable thing that the Jonker's achieved is the time
line for the progress from concept - prototype - competition results
- production - certification. In terms of competitive flying, I think
the Jonkers have the advantage for a while (unless the IGC reinvents the
rules).
But in terms of the market, a lot will depend on engine packages, all of
the manufacturers have a lot of work to do, with both self launchers and
sustainers. I have seen both S-H and Schleicher "self launchers" opting
to take aerotows this season (for heat, maintenance or serviceability
reasons) as well as outlandings from self launchers and sustainers. The
FES's got grounded due to battery fires :-( The only package that seems
to be delivering consistently reliably seems to be the DG's, but they do
not feature in the competitions. And the engine packages are ALL high
maintenance!
Ian
Old January 18th 18, 10:52 AM posted to rec.aviation.soaring
Default More 3's?
DG self launchers use the same Solo engine/Binder pylon systems as SH, EB (Binder) and HPH.
Old January 18th 18, 05:54 PM posted to rec.aviation.soaring
Default More 3's?
Hi Krasw,
apologies for my ignorance in this case, but could you briefly guide me to a link to that Kawa interview/comment?
My (superficial) impression from the last two long final glides was that both ships are performing more or less equally in capable hands even under slightly different conditions
- Tuesday was a 87 Km final glide (with practically identical flight paths from TP 4 with 55 Km to go) at assumed airspeeds above the "optimized" flight envelope (i.e. above 220-230 km/h IAS) - the winning V3 and JS1 crossed the finish line within 9 seconds
- Yesterday the 5 leaders were within 5 seconds after their 100+ Km spectacular ridge line dash at probably more representative speeds around 170-200 Km/h (in this case probably with some small differences in micromanaging their individual flight paths and their willingness to hug the rocks). Even the ASG 29 which is probably a bit handicapped due to the 52 Kg/m2 wingload limit instead of the usual MTOW limitation came in within 25 secs...
With these few data points I was under an initial low confidence impression of some kind of "equality" of V3 and JS 1 at least in the high speed ranges (I have no useful observations regarding handling/climbing differences or performance in the low to mid speed range...) - but obviously a comment from Kawa that the V3 outperforms his JS 1 in final glide would supersede that initial impression.
Thanks and best
Marc
Old January 18th 18, 06:10 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default More 3's?
On Thursday, January 18, 2018 at 11:55:02 AM UTC-5, wrote:
Hi Krasw,
Thanks and best
Marc
The fact that the JS-1 was flown by Kawa might have contributed to it being closer than it might have been! Note that the Ventus2cT also was in the mix, but flown by someone with thousands of hours locally (buy that man a beer!)... It looks to me like the V3 in those conditions is the one to have. It would have been nice to see a JS-3 or two as well.
Old January 18th 18, 06:55 PM posted to rec.aviation.soaring
Andreas Maurer
Default More 3's?
Well...
let me put it this way.
A 33 is in the works, but it won't be be amed ASG.
Cheers
Andreas
