Aichi D3A
Old February 10th 18, 04:04 PM posted to alt.binaries.pictures.aviation
Miloch
Default Aichi D3A
https://en.wikipedia.org/wiki/Aichi_D3A
The Aichi D3A Type 99 Carrier Bomber, (Allied reporting name "Val") was a World
War II carrier-borne dive bomber. It was the primary dive bomber of the Imperial
Japanese Navy (IJN), and was involved in almost all IJN actions, including the
attack on Pearl Harbor.
The Aichi D3A was the first Japanese aircraft to bomb American targets in the
war, commencing with Pearl Harbor and U.S. bases in the Philippines, such as
Clark Air Force Base. Vals sank more Allied warships than any other Axis
aircraft.
The Aichi design started with low-mounted elliptical wings inspired by the
Heinkel He 70 Blitz. It flew slowly enough that the drag from the landing gear
was not a serious issue, so fixed gear was used for simplicity. The aircraft was
to be powered by the 529 kW (709 hp) Nakajima Hikari 1 nine-cylinder radial
engine.
The first prototype was completed in December 1937, and flight trials began a
month later. Initial tests were disappointing. The aircraft was underpowered and
suffered from directional instability in wide turns, and in tighter turns it
tended to snap roll. The dive brakes vibrated heavily when extended at their
design speed of 200 knots (370 km/h), and the Navy was already asking for a
faster diving speed of 240 knots (440 km/h).
The second aircraft was extensively modified before delivery to try to address
the problems. Power was increased by replacing the Hikari with the 626 kW (839
hp) Mitsubishi Kinsei 3 in a redesigned cowling, and the vertical tail was
enlarged to help with the directional instability. The wings were slightly
larger in span and the outer sections of the leading edges had wash-out to
combat the snap rolls, and strengthened dive brakes were fitted. These changes
cured all of the problems except the directional instability, and it was enough
for the D3A1 to win over the Nakajima D3N1.
Role
Carrier-based dive bomber
Manufacturer
Aichi Kokuki KK
First flight
January 1938
Introduction
1940
Retired
1945
Primary user
Imperial Japanese Navy
Number built
1,495
(479 D3A-1)
(1016 D3A-2)
Developed into
Yokosuka D3Y Myojo
The D3A1 commenced carrier qualification trials aboard the aircraft carriers
Akagi and Kaga during 1940, while a small number of aircraft made their combat
debut from land bases over China. Starting with the attack on Pearl Harbor, the
D3A1 took part in all major Japanese carrier operations in the first 10 months
of the war. They achieved their first major success against the Royal Navy
during their Indian Ocean raid in April 1942. Val dive bombers scored over 80%
hits with their bombs during attacks on two heavy cruisers and an aircraft
carrier during the operation. During the course of the war, Val dive bombers
often combined their attacks upon enemy warships with the IJN Nakajima B5N Kate
torpedo bomber; consequently enemy vessels were often sunk by a combination
strike of bombs and torpedoes. However, there were occasions when just the Vals
would make the attacks, or at least score the sinking hits.
Discounting the Pearl Harbor strike, which also used the B5N for level bombing
and torpedo attacks, Val dive bombers were credited with sinking the following
Allied warships:
USS Peary, American destroyer, 19 February 1942 – Australia (Darwin)
USS Pope, American destroyer, 1 March 1942 – Pacific Ocean
HMS Cornwall, British heavy cruiser, 5 April 1942 – Indian Ocean
HMS Dorsetshire, British heavy cruiser, 5 April 1942 – Indian Ocean
HMS Hector, British armed merchant cruiser, 5 April 1942 – Indian Ocean
HMS Tenedos, British destroyer, 5 April 1942 – Indian Ocean
HMS Hermes, British aircraft carrier, 9 April 1942 – Indian Ocean
HMAS Vampire, Australian destroyer, 9 April 1942 – Indian Ocean
USS Sims, American destroyer, 7 May 1942 – Pacific Ocean
USS De Haven, American destroyer, 1 February 1943 – Pacific Ocean
USS Aaron Ward, American destroyer, 7 April 1943 – Pacific Ocean
USS Brownson, American destroyer, 26 December 1943 – Pacific Ocean
USS Abner Read, American destroyer, sunk by kamikaze 1 November 1944 – Pacific
Ocean
USS William D. Porter, American destroyer, sunk by kamikaze 10 June 1945 – Japan
(Okinawa)
As the war progressed, there were instances when the dive bombers were pressed
into duty as fighters in the interceptor role, their maneuverability being
enough to allow them to survive in this role. In June 1942, an improved version
of the D3A powered by a 969 kW (1,299 hp) Kinsei 54 was tested as the Model 12.
The extra power reduced range, so the design was further modified with
additional fuel tanks to bring the total tankage to 900 L (240 US gal), giving
it the range needed to fight effectively over the Solomon Islands. Known to the
Navy as the Model 22, it began to replace the Model 11 in front-line units in
autumn 1942, and most Model 11s were then sent to training units.
Specifications (D3A1)
General characteristics
Crew: Two (pilot and gunner)
Length: 10.2 m (33 ft 5 in)
Wingspan: 14.37 m (47 ft 2 in)
Height: 3.85 m (12 ft 8 in)
Wing area: 34.9 m² (375.6 ft²)
Empty weight: 2,408 kg (5,309 lb)
Max. takeoff weight: 3,650 kg (8,047 lb)
Powerplant: 1 × Mitsubishi Kinsei 44, 798 kW (1,070 hp)
Performance
Maximum speed: 389 km/h (205 kn, 242 mph (389 km/h))
Range: 1,472 km (795 nmi, 915 mi (1,473 km))
Service ceiling: 9,300 m (30,500 ft)
Armament
2 × fixed, forward-firing 7.7 mm (0.303 in) Type 97 machine guns
1 × flexible, rearward-firing 7.7 mm (0.303 in) Type 92 machine gun
1 × 250 kg (551 lb) or 2 × 60 kg (132 lb) bombs
Specifications (D3A2)
Length: 10.2 m (33 ft 5.4 in)
Height: 3.8 m (12 ft 7.5 in)
Empty weight: 2,570 kg (5,666 lb)
Max. takeoff weight: 4,122 kg (9,100 lb)
Powerplant: 1 × Mitsubishi Kinsei 54, 969 kW (1,300 hp)
Performance
Maximum speed: 430 km/h (232 kn, 267 mph (430 km/h))
Range: 1,352 km (730 nmi, 840 mi (1,350 km))
Service ceiling: 10,500 m (34,450 ft)
Rate of climb: 8.62 m/s (1,869.685 ft/min)
Armament
2 × fixed, forward 7.7 mm (0.303 in) Type 97 machine guns
1 × 250 kg (551 lb) and 2 × 60 kg (132 lb) bombs
Aichi E13A pics 1 [09/11] - e13a_7.jpg (1/1) Miloch Aviation Photos 0 August 4th 17 03:34 PM
Aichi E13A pics 1 [04/11] - aichi-e13a.jpg (1/1) Miloch Aviation Photos 0 August 4th 17 03:34 PM
Aichi E13A pics 1 [02/11] - Aichi E13A.jpg (1/1) Miloch Aviation Photos 0 August 4th 17 03:34 PM
Aichi E13A pics 1 [01/11] - Aichi E13A 2.jpg (1/1) Miloch Aviation Photos 0 August 4th 17 03:34 PM
Aichi E13A Miloch Aviation Photos 0 August 4th 17 03:32 PM
