ASW15 vs ASW19
Old March 29th 18, 01:19 PM posted to rec.aviation.soaring
Senna Van den Bosch
Default ASW15 vs ASW19
Hey everyone
I would like to have some opinions on buying a first glider between these two. There are a couple of both for sale that I've seen and my budget would be 10-20k euros.
Would you say the performance difference justifies the price difference? How would they compare at higher speeds and rigging/derigging?
Would the performance of the ASW15 be pretty much the same or within a few % to the Std Libelle, Std Cirrus, ...?
Old March 29th 18, 02:58 PM posted to rec.aviation.soaring
Michael Opitz
At 12:19 29 March 2018, Senna Van den Bosch wrote:
Hey everyone
these
budget would
be 10-20k euros.
difference?
within a few
The -19 is just newer and better. The -15 has balsa wood core
sandwich wings, where the -19 has foam core which will not rot.
There was at least one TM about the balsa sandwich construction
on the -15. Performance of the -15 is similar to STD Cirrus or STD
Libelle. Dive brakes are better than on STD Cirrus because they are
upper and lower. The -19 has only upper, but with the 2 stage mod
(ASW-19B model), they are fine. The -19 has a forward hinged
canopy, where the -15 has the canopy that has to be completely
removed to get out, which is a pain in the rear. There is a -15B
model which has a larger rudder for better yaw control. The -19 has
the new Club Class handicap of 1.0, which will make it a favorite for
Club Class racers because it performs better than that handicap
indicates. You pay for what you get...
RO
Old March 29th 18, 04:24 PM posted to rec.aviation.soaring
Phil Chidekel
Hey everyone
these
budget would
be 10-20k euros.
difference?
within a few
RO
I feel somewhat qualified to discuss the qualities on the ASW 15--I have the pleasure of flying XC in one quite regularly.
First off, I find the ASW 15 to be delightful to fly... Its handling qualities are outstanding. The ailerons and rudder are well balanced and responsive, and I have never found it to possess the "twitchiness" that people fear with other all-flying-tailed gliders. It thermals slow, and it out-climbs most of the other gliders I fly with regularly. I fly a straight 15, so it doesn't have the bigger rudder of the "B" models, and if I am flying aggressively, there are moments where I would appreciate another teensy bit of rudder authority. Not a big deal, but I suppose Gerhard Waibel shared my sentiments when he designed the B model. Mike Fadden graciously checked me out in his when I was a sophomore in High School, with most of my other time to that point being in 1-26s and Blaniks. The transition wasn't an issue.
The big spoilers are a totally great--the 15 will land on a literal handkerchief, and there have been tight moments where I have appreciated this. That being said, it has taken me a long time to learn how to land the 15 fully gracefully. It will spot landing easily, but I find the touchdown attitude to be very sensitive: two point attitude is *not quite* fully stalled. It could use a slightly bigger wheel--once again, I must not be the only one who thinks this, as the taller gear was added on the B model.
Assembly is a complete joke--the wings are very light, and almost always go together without any serious jiggling. I think John Bird and I could win a timed rigging contest if given the opportunity--if we try, we can have a 15 assembled, taped, PC-checked, and ready to fly in 15 minutes.
The performance? I would describe it as an honest 30:1 glider, but this has not discouraged me. I have learned a lot from flying something that isn't a super ship, and if flown well, it will keep up with a Discus.
The fully removable canopy is annoying.
I have access to a Pegasus (I know, I know, it's not a -19, but it is close), and honestly, I prefer flying the -15. The 15 is a very honest glider, and I can land it anywhere. The Peg is nice, but it doesn't have *that* much more performance, and it is a bit more of a pain to deal with. Given the ease of rigging the 15 and my comfort level in its characteristics, the choice is easy--it allows me to fly more. Plus, the shark tail is so damned good-looking.
The spar inspection is accomplished at annual every year. Keep it dry and give it the love it needs... But I fly it on the [varying levels of violent] ridges of Central PA, and have never worried about the wings falling off. Knock on wood(en wing spars).
Bottom line: for the money, I would totally buy a clean ASW 15. They are great little gliders.
Looks like a ridge day on Sunday...
Cheers.
Phil Chidekel
ASW19/20 Canopy strut [email protected] Soaring 10 July 3rd 17 03:16 PM
ASW19 for sale [email protected] Soaring 2 September 12th 16 10:07 PM
ASW19 Inner Tube [email protected] Soaring 1 September 21st 15 03:54 PM
asw19 airbrake kit steve[_2_] Soaring 2 April 7th 11 08:32 PM
ASW15 Site Johan Soaring 0 June 15th 04 04:08 PM
