What products have been used to fill the aluminum caps of schempp-Hirth gliders during a refinish? are repairs using just a thick coat of primer surfacer like prestec? or is there something else used. the aluminum surface of my Std. Cirrus is a good .040 or more below the wing surface. I would expect something with some flexibility might be used but the original stuff is pretty crispy.
Thanks, Scott |
I have had good success using Evercoat Rage sanding body filler. I thoroughly clean the cap surface along with the well and underside of brake plates, then line the whole area with aluminum foil, then close and lock the spoilers. If your spoilers don't lock inside the wing, you will need to come up with a method to apply enough closing pressure to make the spoiler caps seat all around (believe we used a wooden stick that jammed against the root rib to keep them locked on a LS-3a) mix up a good batch of Rage and spread it evenly into the well........may take several applications to get everything high. Then cross sand with an 18" long board and 40 grit paper, 45 left then 45 right strokes till you start cutting into the aluminum foil. At this point you can fine fill with Evercoat finishing and blending putty followed by heavy primer, etc.
Feel free to email me with any specific issues, JJ |
Glider Wraps, Gelcoat Refinishing | Herbert kilian | Soaring | 18 | September 27th 12 12:53 AM |
Book on Glider Refinishing | Scott Alexander | Soaring | 2 | September 3rd 08 09:08 PM |
Glider repair/refinishing | [email protected] | Soaring | 2 | November 23rd 05 03:00 AM |
Commercial Glider refinishing book | Martin Carolan | Soaring | 0 | December 15th 03 09:41 AM |
Glider refinishing | Janusz Kesik | Soaring | 0 | December 9th 03 05:13 PM |
