making Ventus wingtip tie downs- instructions
Old April 30th 18, 06:18 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default making Ventus wingtip tie downs- instructions
OK, there is enough interest that I am posting instructions on how to make these. It is actually pretty simple, but you will need access to a lathe, drill press, etc.
1) download the purchased parts list here (https://www.dropbox.com/preview/Publ...?role=personal) and order the parts from McMaster. You only need two of the carabiners, or you can substitute a SS threaded link as I did: PN:8947T26
2) Machine the three parts (X2 each) from drawings provided here
for the SS wing tip tie down, just print out the drawing, paste onto the sheet metal, and use it as a template for drilling and shaping
3) assembly
a) disassemble the cam handle and thread the rod into the tie down jack (thru the end with the O ring step) so that it protrudes about 1.9 inches. Re-drill the 1/16" hole in the tie down jack thru the rod and press in the spring pin so the rod can't unscrew. make sure the pin is recessed below the surface of the Delrin so it won't scratch your wingtip tube wall.
b) drop the O ring over the rod onto the tie down jack
c) slide the tie down spacer over the rod.
d) slide the wing tip tie down over the rod.
e) re-assemble the cam handle onto the rod and screw it in until the O ring is squished when the cam handle is engaged
DONE!
4) to use this gizmo, remove wingtip, and slide in the tie down. Flip the lever downward and adjust as needed for the right amount of axial retention.. It should be almost impossible to pull out the tie down from the wingtip tube. Attach a rope thru the threaded link and secure the wing. I like to use a rolling hitch to cinch the wingtip down easily. See: https://en.wikipedia.org/wiki/Rolling_hitch for how to tie this fabulous knot.
Let me know how it goes!
Cheers,
Matt
Free Ventus wing tie downs Matt Herron Jr. Soaring 10 May 7th 18 03:52 PM
Bad Tie Downs GARY BOGGS Soaring 5 November 28th 11 01:12 AM
Ratcheting tie-downs vs come-alongs? Michael Horowitz Home Built 3 July 26th 08 04:31 AM
tie downs in the bush tom pettit Piloting 12 August 23rd 05 10:02 PM
titanium ti-downs [email protected] Home Built 0 July 16th 05 12:46 AM
