Becker Transponder E10 error message
Old May 11th 18, 11:10 PM posted to rec.aviation.soaring
Steve Cameron
Default Becker Transponder E10 error message
I've recently bought a glider that has an older Becker transponder(mode c), and every time I turn it on it invariably displays the E10 error code. In reading past reports of this issue(2006/2008) on the net this seemed to be a fairly common occurence, with no real solution. Becker says its a transmission fault involving the antenna and or ground plane. My local avionics shop tested it for the two-year cert, everything checked out OK, than at the end of the check the E10 pops up. We've tried adding a short piece of coax at the antenna end, as well as insuring the ground plane is truly grounded. So far nothing seems to rid the error message. My avionic tech here seems to think it was a design flaw in the unit, and I'm very tempted to just scrap it and move on. Is there anyone out there who has successfully dealt with this issued?
Thanks
SC
WTB Becker Transponder Retting Soaring 1 December 27th 17 10:41 PM
Important message about transponder use Fred[_5_] Soaring 6 February 17th 12 06:48 PM
FS: Becker Transponder Fox Two Soaring 2 October 30th 10 12:55 AM
How to disable PDA connections to avoid error message? Barny Soaring 6 April 18th 10 05:05 PM
Garmin 430 error message: "com requires service"??? Guy Byars Owning 2 July 26th 05 03:28 AM
