Becker AR 620x radio - seems a little quiet?
Old May 18th 18, 10:23 PM posted to rec.aviation.soaring
jfitch
Default Becker AR 620x radio - seems a little quiet?
I finally got my new radio wired, the audio seems a little quiet compared to the old Dittel 71. Same speaker, 4 ohm as spec'd. I remember the Dittel being pretty loud, kept the volume knob set to the lower half of rotation. The Becker even at 100% is far from earsplitting, and maybe not loud enough at speed or with the engine running. Both the Becker and Dittel spec'd at 4W audio power into 4 ohms.
Has anybody experienced this?
Old May 19th 18, 12:48 AM posted to rec.aviation.soaring
Do you have a back seat repeater installed? Might check the volume knob there if so.
Old May 19th 18, 09:13 AM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
t=
b=
enough=
at
At risk of asking the obvious, is you speaker wired across P1-1/P1-14 and
not the headset pins?
I the configuration:
Is speaker ticked in IN/OUT CFG1/2?
Is SPKR VOL SRC set to Primary?
Old May 19th 18, 02:38 PM posted to rec.aviation.soaring
My 4201 is quit too.
DC
Old May 19th 18, 02:39 PM posted to rec.aviation.soaring
My 4201 is quiet too.....
DC
Old May 19th 18, 03:20 PM posted to rec.aviation.soaring
jfitch
t=
b=
eing pretty loud, kept the volume knob set to the lower half of rotation..
enough=
at
Speaker is correctly wired and turned on in CFG. There is no back seat, and no second control - though it is mounted remotely using one control. "SPKR VOL SRC set to Primary?" - that I will check. I can vary the volume with the knob, it just doesn't go very high. At 100%, it is about as loud as the Dittel was on 1/3, using the same speaker.
Old May 19th 18, 10:47 PM posted to rec.aviation.soaring
jfitch
t=
b=
enough=
at
'Is SPKR VOL SRC set to Primary?' Bingo! You, Sir, win the toaster oven. That parameter was set to "Both" and the moment I set it to "PRI" it practically blew me out of the cockpit. Now have the volume set at 25% which is about as loud as the Dittel was. Intuitively it seems like Both should have worked the same but practically, it doesn't.
Becker AR3201 Radio need help [email protected] Soaring 4 July 31st 14 03:06 AM
Becker radio repair [email protected] Soaring 7 March 10th 10 03:14 PM
Becker 3201 Radio [email protected] Soaring 8 December 8th 05 03:08 PM
Becker Radio Repair Steve Leonard Soaring 2 August 23rd 05 05:00 PM
Becker radio AD Tom Serkowski Soaring 3 November 2nd 04 01:43 AM
