Tape the pitot/static system during storage?
Old May 24th 18, 02:46 PM posted to rec.aviation.soaring
Default Tape the pitot/static system during storage?
Hi all.
From advice from another soaring pilot, I've been taping my pitot/static inlets with red electrical tape when I store my glider. This is done to keep bugs out during storage.
I started wondering if changes in air pressure could cause the airspeed and/or altimeter and/or vario calibrations to go out of whack.
Seeking knowledgeable opinions on this one.
Ben Ethridge
Old May 24th 18, 03:02 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I use a fuel filter with rubber tubing Keeps bugs out but air can move.
Old May 24th 18, 03:53 PM posted to rec.aviation.soaring
I always plug my triple prope every time I remove the probe, because I have had "leaf-roller" bugs build a nest in one afternoon! Wings and Wheels sells a nice little plug with a red streamer attached to it.
For the guy with a ruptured diagram in his ASI, I would bet someone blew out the line with compressed air..............don't ask me how I know this to be the most probable cause?
JJ
Old May 24th 18, 11:34 PM posted to rec.aviation.soaring
Bob Kuykendall
I remember watching Les Sebald clean a glass instrument lens out of the cockpit of a Grob. He was blowing the static system out with compressed air, and forgot to disconnect one of the instruments. Oopsie.
I doubt that there is much chance of harm from pressure changes while the static ports are taped over.
Old May 25th 18, 12:17 AM posted to rec.aviation.soaring
Some instruments, like Sage variometers are highly likely to be damaged by the pressure pulse of pulling tape off after a big pressure change. I know from experience.
One can tape statics so the top is protected from moisture while leaving a small "wrinkle" below that will allow breathing.
FWIW
UH
Old May 25th 18, 02:59 AM posted to rec.aviation.soaring
kirk.stant
I made a Pitot cover for my LS6 (fin pitot) with a length of rubber tubing (medical type) that has some yaw string yarn inserted in it, and red tape wrapped around it to make it nice and visible. It is easy to slip over the pitot tube, and any critter would have to go a long way past the yarn to get to the tube.
No critters so far (had them in the past; went to the Grand Canyon once from Turf without any ASI or nav computer - but it was too good a day to pass up!)
OT, but when I leave my glider rigged in our hangar with the TE probe in, I slip on one of those red REMOVE BEFORE FLIGHT banners that have a grommet at the end - which fits perfectly on my Ilec TE probe. Easy to see and helps prevent someone hitting the probe in a dark hangar and damaging the in-fin connector. Another reason for TE probes to point UP ;^)
Kirk
66
Old May 25th 18, 03:27 AM posted to rec.aviation.soaring
Uli is correct about Sage variometers. To keep bugs out of my static, yet not exposing my expensive Sage CVA vario to pressure pulses, I covered each static port with a 1"x1" square of fabric and taped around the edges of the fabric.
Old May 25th 18, 07:27 PM posted to rec.aviation.soaring
Band-aids have the fabric and adhesive already installed.
BV
Old May 25th 18, 07:36 PM posted to rec.aviation.soaring
BV
Sorry, that's a band-aid solution. :-)
Old May 25th 18, 11:29 PM posted to rec.aviation.soaring
When I tape up the statics and triple probe socket for winter storage, I just prick the tape with a pin or knife point. I'm not sure it's necessary but I just don't want to worry about it.
Chip Bearden
Pitot system - odd event Del Jensen Soaring 19 May 25th 18 11:35 PM
New Glider Static / Pitot / TE Checkout MNLou Soaring 3 April 11th 15 07:48 AM
Pitot/Static/Transponder Problem Kyle Boatright Home Built 26 August 18th 07 09:31 PM
pitot/static location Ray Toews Home Built 2 December 30th 03 01:52 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 08:25 AM
