Resetting a Bienno LiFePO4 Battery
Old June 26th 18, 05:01 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Default Resetting a Bienno LiFePO4 Battery
A friend of mine was having an odd problem with his Bienno LiFePO4 battery that I had never seen before. He lent me his battery while I was working on his panel. https://www.bioennopower.com/collect...epo4-batteries
The next day I was surprised when the battery didn't power up the panel. So I measured the output voltage of the battery. It was 2Vdc! That's not a typo, it was only two volts! Very strange. I put the battery onto the appropriate Bienno branded charger (which I assume is a dumb charger).
The next day the battery was back at an appropriate 13.5Vdc. Used it a bit to test the panel then disconnected it from any load. Next day the battery was back at ~2Vdc again! Repeating the charging cycle and same deal - OK at first then 2Vdc later. Something internal to the battery seemed to be draining the battery.
The friend contacted Bienno and they replied;
Please try the following:
1) Attach the charger to the battery. Connect the AC-to-DC charger to the AC outlet.
2) *Simultaneously* to the battery, please attached [sic] a load (12V load such as LED light, or GPS etc.). Turn on the load for 20 seconds.
3) This will force a reset of the battery.
The friend reports that this fixed his issue. I assume this resets the battery's internal power management system which must have been draining the battery.
Anyone else seen this issue? I own two of these same batteries and have not.. Could this fault cause long term damage to the battery?
Thanks, John OHM Ω
V7 vario resetting in flight [email protected] Soaring 8 February 21st 14 05:29 PM
LiFePO4 battery technolocy [email protected] Soaring 9 October 17th 12 11:05 PM
LiFePO4 battery ASM Soaring 4 December 6th 11 08:00 PM
Resetting Winter Vario to Zero? ContestID67 Soaring 16 April 4th 06 03:44 PM
resetting mixture xerj Piloting 4 June 24th 04 06:31 PM
