On Thursday, September 27, 2018 at 10:06:46 AM UTC-4, son_of_flubber wrote:
https://www.nytimes.com/2018/09/26/b...lar-power.html If it is as "simple" as claimed, why is the circuit board (seen in the photos in the article) so complicated? Also, this has been in development for some years, so clearly there are some significant obstacles (see he https://en.wikipedia.org/wiki/Zinc%E...hargeable %29 ). If they've solved them, cool! |
On Thu, 27 Sep 2018 08:12:09 -0700, moshe.braner wrote:
On Thursday, September 27, 2018 at 10:06:46 AM UTC-4, son_of_flubber wrote: https://www.nytimes.com/2018/09/26/b...ironment/zinc- battery-solar-power.html If it is as "simple" as claimed, why is the circuit board (seen in the photos in the article) so complicated? Also, this has been in development for some years, so clearly there are some significant obstacles (see he https://en.wikipedia.org/wiki/ Zinc%E2%80%93air_battery#Secondary_%28rechargeable %29 ). If they've solved them, cool! I notice the article doesn't mention the energy density, capacity or charge/discharge rates of that battery. Without this info we can't know whether this technology is only useful for powering lightbulbs, radio repeaters etc. or if it has enough grunt to run a car or an FES system. In this the NY Times is, little better than New Scientist, which periodically talks up some doctoral student's new, lab-scale battery technology that, thesis written, is never heard of again. -- Martin | martin at Gregorie | gregorie dot org |
"....which periodically talks up some doctoral student's new, lab-scale battery
technology that, thesis written, is never heard of again." That also describes "Gliding International" when it comes to battery technology, electric airplanes and the like. |
On Thursday, September 27, 2018 at 6:00:40 PM UTC-4, wrote:
"....which periodically talks up some doctoral student's new, lab-scale battery technology that, thesis written, is never heard of again." That also describes "Gliding International" when it comes to battery technology, electric airplanes and the like. Ultra capacitors ! |
Ultra capacitors ! A gallon of gasoline contains 120 million Joules of energy. Now use this website to calculate what size ultra capacitor you would need to achieve this amount. http://hyperphysics.phy-astr.gsu.edu...ic/capeng.html |
On Fri, 28 Sep 2018 07:48:13 -0700, Soartech wrote:
Ultra capacitors ! A gallon of gasoline contains 120 million Joules of energy. A more useful equivalent for comparison is that a litre of petrol is as near as dammit 10 kWh in energy terms - and petrol spiked with methanol will be a bit less: 9-9.5 kWh at a guess, So a US gallon (3.78l) would be the equivalent of 37.8 kWh of unadulterated petrol or 34-36 kWh if its a gasoline/methanol blend. By comparison, the Gen 2 FES battery has 14 cells, each of 2.1 kWh, or 29.4 kWh for the standard 14 cell pack, so an hPh Shark (dual packs carried has just less than 60kWh of energy onboard, or 1.6 US gallons of avgas equivalent. The dual packs are about 18 litres total volume, so on a volumetric basis they're about 1/3 as good as petrol when it comes to storing energy in limited space. -- Martin | martin at Gregorie | gregorie dot org |
Dammit, I hate it when someone uses math to prove a point... :-D
On 9/28/2018 9:58 AM, Martin Gregorie wrote: On Fri, 28 Sep 2018 07:48:13 -0700, Soartech wrote: Ultra capacitors ! A gallon of gasoline contains 120 million Joules of energy. A more useful equivalent for comparison is that a litre of petrol is as near as dammit 10 kWh in energy terms - and petrol spiked with methanol will be a bit less: 9-9.5 kWh at a guess, So a US gallon (3.78l) would be the equivalent of 37.8 kWh of unadulterated petrol or 34-36 kWh if its a gasoline/methanol blend. By comparison, the Gen 2 FES battery has 14 cells, each of 2.1 kWh, or 29.4 kWh for the standard 14 cell pack, so an hPh Shark (dual packs carried has just less than 60kWh of energy onboard, or 1.6 US gallons of avgas equivalent. The dual packs are about 18 litres total volume, so on a volumetric basis they're about 1/3 as good as petrol when it comes to storing energy in limited space. -- Dan, 5J |
On Friday, September 28, 2018 at 9:58:43 AM UTC-6, Martin Gregorie wrote:
On Fri, 28 Sep 2018 07:48:13 -0700, Soartech wrote: Ultra capacitors ! A gallon of gasoline contains 120 million Joules of energy. A more useful equivalent for comparison is that a litre of petrol is as near as dammit 10 kWh in energy terms - and petrol spiked with methanol will be a bit less: 9-9.5 kWh at a guess, So a US gallon (3.78l) would be the equivalent of 37.8 kWh of unadulterated petrol or 34-36 kWh if its a gasoline/methanol blend. By comparison, the Gen 2 FES battery has 14 cells, each of 2.1 kWh, or 29.4 kWh for the standard 14 cell pack, so an hPh Shark (dual packs carried has just less than 60kWh of energy onboard, or 1.6 US gallons of avgas equivalent. The dual packs are about 18 litres total volume, so on a volumetric basis they're about 1/3 as good as petrol when it comes to storing energy in limited space. -- Martin | martin at Gregorie | gregorie dot org But, an electric motor is more than three times as efficient as an internal combustion engine - 98% vs. 33% - so they don't need as much 'fuel'. |
| Thread Tools | |
| Display Modes | |
| PowerFLARM portable: rechargeable battery recommendations | ursus | Soaring | 1 | February 1st 12 07:02 PM |
| Harry (finally) lights the torch! ...and etches some zinc off too! | wright1902glider | Home Built | 29 | February 22nd 09 07:23 PM |
| Powdered zinc oxide? | Michael Horowitz | Home Built | 4 | November 2nd 08 02:57 PM |
| Typhoon 'How much closer do you want me' | Grouper | Aviation Photos | 1 | May 25th 08 02:54 AM |
| Zinc Chromate in 2005 | Michael Horowitz | Home Built | 4 | October 16th 05 07:44 PM |
